Wider is not always better
Old Mar 2, 2009 | 09:56 PM
  #21
dodge15004x45.9's Avatar
dodge15004x45.9
Originally Posted by 96RamSLT
prolly is the bfg.. just a generic version.. you know tire companies make cheaper generic tires but are actually the same thing.
Yea I know I got all four shipped to my house for 488.04. And I might me able to help you out with rim. Just got 16X8 dick cepek's and I'm not sure if I want to get rid of the stock ones yet you will need new tire. My dad made a comment about my new rims he called them fufu wells lol.
Old Mar 2, 2009 | 09:57 PM
  #22
hometheaterman's Avatar
hometheaterman
I don't usually have to drive a ton in the snow only a couple times a year but my BFG Mt's do decent. I do have to put it in 4wd some going up hills or if I stop on a hill as they do slide and stuff but they seem to dig down pretty well through the snow at the same time if you get them spinning.
That said a skinnier tire would probably do better as well, it's pretty well known that wider tires float and skinnier tires cut through it.
Old Mar 2, 2009 | 10:21 PM
  #23
LegendKiller89's Avatar
LegendKiller89
Ain't gonna lie I've never had problems with wider tires. I have 33x12.5's on my truck and not one problem.
Old Mar 3, 2009 | 08:51 AM
  #24
05DodgeRamHemi's Avatar
05DodgeRamHemi
My suspicion would be because you have a mud terrain. I think a mud-terrain can get away with a little more width because of those lugs. As I said earlier, my 35" mud tires did decent in the snow. I have a feeling that a wide all-terrain tire just doesn't do well. It's wide and doesn't have much to grip.
Old Mar 3, 2009 | 09:13 AM
  #25
Silver_Dodge's Avatar
Silver_Dodge
The real question is, at what point in width does a tire go from cutting into snow to floating on snow. I have a hard time believing that it is somewhere between a 285 and a 305. The tires on my Swift are about 6" wide - they cut pretty good through snow. I bet if I put something wider, id feel like it was floating too, even though I'd still be narrower then your 285's.
Old Mar 3, 2009 | 12:18 PM
  #26
05DodgeRamHemi
I'd say it depends on the weight off a vehicle, and the wheelbase as well. My brother would probably have better traction with 305s on his one ton than my half ton with 305s. What is a swift??
Old Mar 3, 2009 | 12:47 PM
  #27
Silver_Dodge
Originally Posted by 01DodgeRam360
.....What is a swift??
It's my gas sipper. A cheese wedge on wheels with a gerbil under the hood.
Old Mar 3, 2009 | 04:26 PM
  #28
05DodgeRamHemi
LoL. How often do you use truck would you say?
Old Mar 3, 2009 | 04:40 PM
  #29
Mowhawk's Avatar
Mowhawk
Why not throw on some sweet bead lock rims and lower the PSI in the tire? and for me with my 33/12.5 pro comp M/Ts I rip through the snow around here. But of course in PA we dont get anything above 12. Still though, traction when i want it and in 4x2 playin in the snow in parkin lots
Old Mar 3, 2009 | 04:41 PM
  #30
zman17's Avatar
zman17
Retired Moderator - RIP
I've been using a 95 VW Cabrio for commuting purposes, because it gets close to 35mpg. When the weekend comes, I can't wait to fire up the Ram, and run over some VW's, LOL
