Iac valve always opening
Old Mar 3, 2009 | 07:15 PM
mcss8541's Avatar
mcss8541
Angry Iac valve always opening
Hello everyone, this question is regarding the IAC valve. During cold starts the engine starts to stumble for a few minutes and you can hear the IAC valve opening and a loud air noise I'm assuming letting more air in, this will correct the problem raising the rpm's then it will start the process over again until after a few minutes the engine will idle normally. I have had this problem for the 2 yrs I've owned the truck, in some cases this will cause a CEL with the culprit normally being CYL 5 MISFIRE with the latest CEL being no 6. After pulling all of the injectors and fuel rail and cleaing them and reaplcing all of the rubber "O" ring gaskets on the injectors the truck ran fine for a couple of days then today while the truck was idling the dag gone CEL popped on again and it was the infamous #5 misfire again. When I came out of my house to leave the truck started stumbling really bad almost dying and the IAC opened up again and you could hear that lous air sucking noise again coming from it. The engine was warm this time and even after I gunned the engine a few times it continued. After a few minutes it leveled off but the #5 miss was very noticeable. Any ideas? The IAC valve is new as is all of the ignition parts ( ie. plugs, wires, cap, and rotor).
Old Mar 3, 2009 | 09:04 PM
aim4squirrels's Avatar
aim4squirrels
try a new TPS
Old Mar 4, 2009 | 01:04 AM
mcss8541's Avatar
mcss8541
Originally Posted by aim4squirrels
try a new TPS
Hey thanks Aim. The one that's on there is less than a year old however I noticed when I unplugged it to remove my injectors and fuel rail the snap part that keeps it snug when plugged in , was broken. Could this cause issues? Would a small zip tie work?
Old Mar 4, 2009 | 07:25 AM
aim4squirrels
anchor it however you cna, just don't use so you can replace it if need be.
Old Mar 4, 2009 | 08:01 AM
ophidia's Avatar
ophidia
Not a morning person? :P
Old Mar 4, 2009 | 08:42 AM
aim4squirrels
LOL, apparently not.
it's CAN and don't use glue.
Old Mar 4, 2009 | 08:43 AM
mcss8541's Avatar
mcss8541
Will do Aim and thanks again.
