hard start
Old Mar 4, 2009 | 11:32 PM
rowanimal's Avatar
rowanimal
Default hard start
I have a 1996 Ram 5.2 with a slow start. I just replaced the fuel quick connect and the pressure is about 48psi. Once running the truck is great. It just chokes a little sometimes. Other times it starts fine. How can I tell if this is a fuel delivery problem or a cam or crank sensor issue or other wise. The fuel pump is new and the injectors were cleaned at napa.
Old Mar 4, 2009 | 11:57 PM
J415's Avatar
J415
have you looked at your ignition system? what lead you to believe it's your fuel system that's the problem?
Old Mar 5, 2009 | 12:49 AM
rowanimal's Avatar
rowanimal
I could smell gas when I parked and after a while it started leaking around the top of the pump. I am not sure if its ignition related, but at least I think I had a fuel or vapor leak. I took it down to Advance for a code run, but it doesn't show any.
Old Mar 5, 2009 | 01:22 PM
rowanimal's Avatar
rowanimal
Default please help with hard start
This morning I moved around the asd, fuel, and starter relays. They seem fine. Like I posted before, the fuel pressure is about 48 psi. The truck is not showing any codes so I am guesing the cam sensor and the crank sensor are ok. Once the truck starts it is absolutely fine. So I don't think it is the crank sensor. Could it be the distributor or wires? The spark plugs are clean and well gaped.
Old Mar 5, 2009 | 05:17 PM
zman17's Avatar
zman17
Retired Moderator - RIP
After you connect the pressure gauge and start the truck to read the pressure, turn the motor off and watch the pressure gauge for 5 or 10 minutes and see what the pressure does.
Old Mar 5, 2009 | 10:27 PM
J415's Avatar
J415
as far as the plug wires are concerned, did you route them according to the TSB?
http://dodgeram.info/tsb/1998/18-48-98.htm
http://dodgeram.info/tsb/1998/18-48-98/18-48-98-v8.htm
Old Mar 6, 2009 | 12:59 PM
rebel01m's Avatar
rebel01m
i have somewhat the same problem with my 98 dodge 1500
