Why!?
Old Mar 5, 2009 | 10:10 PM
96RamSLT's Avatar
96RamSLT
the ticking could just be an exhaust leak.. mine ticks like hell because i blew my intake manifold gasket.. im just waiting for warm weather, and i am either replacing both sides or putting headers on.. thats why its still not fixed.
Old Mar 5, 2009 | 10:24 PM
dodge15004x45.9's Avatar
dodge15004x45.9
thats what i need to do my truck is make a screech/wisel sound and a tune up!
Old Mar 5, 2009 | 11:59 PM
truckermatt01's Avatar
truckermatt01
idk if anyone said this yet b.c im too lazy to read but check your throttle postioning sensor
Old Mar 6, 2009 | 12:18 AM
RAZRAM's Avatar
RAZRAM
what should i be looking for on the tps?
Old Mar 6, 2009 | 02:15 AM
truckermatt01
my friend pluged into my computer and it showed that everytime i hit the gas the tps wouldnt pick up until about 5 seconds after. so i was just getting the worst gas mileage. so i picked up a new one at auto zone for 30 bucks and threw it in easy as pie and ive been getting great mileage since
Old Mar 6, 2009 | 11:22 AM
dodge15004x45.9
Its a dodge what do you want a chevy or ford lol.
Old Mar 6, 2009 | 11:33 AM
talon6's Avatar
talon6
have you checked the plenum yet? more than likely thats the problem.
Old Mar 6, 2009 | 01:51 PM
audiomechanic's Avatar
audiomechanic
Originally Posted by zman17
You have to plug up the PCV valve hose and the nipple where it's connected to the intake manifold, and also remove the breather hose from the air intake and plug it. Then you can check at the dipstick tube. Only do it for like 30 seconds, no more.
Woops. Forgot to include that. Another was to check is for suction at the breather on the driver's side valve cover. When my plenum blew, there was a ton of suction through that fitting.
Best way I know of is to look down your throttle body for oil at the bottom
Old Mar 6, 2009 | 05:31 PM
RAZRAM's Avatar
RAZRAM
theres deffinately suction from the drivers side valve cover breather. ill check out to see if theres oil inside tomorrow.
Old Mar 6, 2009 | 05:46 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Best way? Just opening up the butterflies and looking in won't tell you anything. You need one of those small round extending mirrors to get down in there and look at all 4 corners. It's also by far not the easiest. Removing the air intake ,getting a mirror and trying to see something with a flashlight while your draped over the grill is more of a PITA, then disconnecting and plugging up a couple hoses and a nipple, and sticking your finger on the dipstick tube. JMO
