transmission slipping
Old Mar 7, 2009 | 08:18 PM
lumpydump's Avatar
lumpydump
Default transmission slipping
hello i have 3 years on a transmission rebuild and now its starting to slip out of gear when driving. it does it mostly when im making a left turn really weird and when coming to a stop it jumps around and sometimes stalls any thoughts fluid is full. when it was rebuilt they put a new pump in it a new converter, clutch drum, pressur transducer, solenoid , governor solenoid and sun gear.
info 1998 dodge 1500 automatic 318 engine 4x4
Old Mar 9, 2009 | 07:34 PM
lumpydump's Avatar
lumpydump
rechecked fluid it was low theres a leak in one of my lines. refilled with fluid and it stopped jumping around when i come to a stop BUT it still slips out of gear when i make a left turn motor revs up and then clunk back in gear . i can make right turns all day no problem straight ahead no problem left turn problem!! any thoughts
Old Apr 15, 2014 | 04:37 PM
lumpydump's Avatar
lumpydump
Started doing it again. When turning left it slips out of gear and then clunk back in gear. Any thoughts it didn't do it for a long time and now started again
Old Apr 15, 2014 | 05:00 PM
What's fluid level look like this time? (be sure to check it with trans in neutral.)
Old Apr 15, 2014 | 10:23 PM
mrau92me's Avatar
mrau92me
...and dont forget the engine's supposed to be running too when checking the fluid
Old May 2, 2019 | 12:07 PM
Brjustfun's Avatar
Brjustfun
Default Trans slips turning left
My 2001 dodge does the same thing slips turning left. I found this on another site.
i just had that same problem solved at the dealership...they replaced a sensor and a transductor located inside the transmission valve body...or somewhere in there. But the problem is gone, and i think mine had the problem since it came out of the factory, because shifts much better than when i got it new.
hope this helps. I am going to the dealership next week.
Old Sep 21, 2021 | 08:51 AM
Coreytilley's Avatar
Coreytilley
same just did it to me
Old Sep 23, 2021 | 10:27 AM
moorefield's Avatar
moorefield
Contact the transmission shop that did the work. They will know what this issue is and maybe give you a discount on correcting the problem.
