puting coolant back in after draining the engine block
Old Mar 9, 2009 | 08:50 PM
madmax0r's Avatar
madmax0r
Default puting coolant back in after draining the engine block
Hey,
I got a quick question, I just drained my engine blocks coolant. I know on some cars your supposed to get the block filled back up first. not just pour in the radiator and go.
If your block is completely drained, can you just pour new coolant in the radiator and then start your truck on the 360?
thanks
Old Mar 9, 2009 | 09:05 PM
dhvaughan's Avatar
dhvaughan
yes. water pump will pull it in and recirculate it within the block.
Old Mar 9, 2009 | 09:38 PM
dblj16380's Avatar
dblj16380
If your really concerned you could just take your t-stat housing off and fill your block up from that opening and then put the t-stat back in and fill the radiator.
Old Mar 9, 2009 | 09:46 PM
madmax0r's Avatar
madmax0r
gotcha, good idea
