no low beams unless steering wheel is all the way up
Old Mar 10, 2009 | 05:46 PM
jreisman's Avatar
jreisman
Default no low beams unless steering wheel is all the way up
today i lost low beams unless i put the steering wheel in the highest position it will go high beams work unless i hit a bump any body else out there had this problem i know another 2nd generation owner and he has the same problem but has not fixed it
Old Mar 10, 2009 | 05:49 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Take the covers off the steering column and check the wires where it swivels, you got a bad one.
Old Mar 10, 2009 | 06:03 PM
TMS Bill's Avatar
TMS Bill
There's a connector in there that can get loose ... I've heard of this before.
Old Mar 10, 2009 | 06:44 PM
jreisman's Avatar
jreisman
thanks, I'll check it out.
Old Mar 11, 2009 | 07:15 AM
dblj16380's Avatar
dblj16380
I had this problem on my old 95 Grand Prix that I had. My brother (certified mechanic) told me that from using the tilt wheel all the time the wires in the multifuntion switch (turn signals, high beams, wipers, etc) tend to wear out over time and will then short out causing miscellaneous problems related to those things. You could try to look for a bad wire or replacing the switch should surely solve the dilema.
From the sounds of it the wire only makes the proper contact with the steering wheel up high and as soon as you budge it it disconnects/shorts out.
I ran into this problem on my wifes truck but hers acted like the left blinker bulb was out. It would blink much faster than usual and then after about a day or two it started to smoke (no doubt from shorting out) in the steering column when you turned the left signal on.
Old Mar 11, 2009 | 08:51 AM
TMS Bill's Avatar
TMS Bill
Everything that's happened before ... WILL happen again: https://dodgeforum.com/forum/2nd-gen...ilt-wheel.html
Old Mar 11, 2009 | 09:12 AM
dblj16380's Avatar
dblj16380
Damn TMS, you win!
Old Mar 11, 2009 | 10:24 AM
TMS Bill's Avatar
TMS Bill
Funny the things you remember ... I read that 2 years ago.
