Lights behind grille
Old Mar 11, 2009 | 01:47 PM
01dabram20's Avatar
01dabram20
Default Lights behind grille
I have some 100w daylighters i want to put behind my grille. I checked the other day and I have to get new tubing and bend it so i can fit the lights there. Would that be to hot for the grille or would I be better off getting some different lights to put there?
Old Mar 11, 2009 | 01:56 PM
Viper37's Avatar
Viper37
Get some Hella 500's. They fit right behind the grille and only need a 6 inch piece of flat stock to mount. No cutting or drilling required.
Old Mar 11, 2009 | 02:00 PM
01dabram20's Avatar
01dabram20
Ill have to look into those.
Old Mar 11, 2009 | 04:55 PM
Viper37's Avatar
Viper37
I've got a pair of those in 55watt HID. They barely get warm. That's HID though. No idea about halogen.
Old Mar 11, 2009 | 06:01 PM
01dabram20's Avatar
01dabram20
how much did that kit cost for those lights?
Old Mar 11, 2009 | 06:21 PM
Viper37's Avatar
Viper37
The kit was 70, the lights were 70.
You can retrofit a pair of the lights in 35 watt hid for about $100 now.
As in, 70 for the lights, 30 for the HID's.
HID's are cheap now.
Old Mar 12, 2009 | 08:50 AM
MiaTurbo's Avatar
MiaTurbo
Putting lights behind the grill will drastically reduce it's side to side output. It will make them more of a 'pencil' beam.
Old Mar 12, 2009 | 09:50 AM
01dabram20's Avatar
01dabram20
I know i will lose side output. I like the look of lights behind the grille though. Its just I will have to get different lights because my kc daylights wont fit behind the grille with out bending new metal pipes to make it fit.
Old Mar 12, 2009 | 01:46 PM
Viper37's Avatar
Viper37
Not with HID they wont.
Old Mar 12, 2009 | 02:44 PM
01dabram20's Avatar
01dabram20
Viper37 did you have to get a higher output Alternator or you still using the stock one?
