2001 RAM 4X4 panic braking problem
Old Mar 1, 2005 | 01:47 PM
jay6ird's Avatar
jay6ird
Default 2001 RAM 4X4 panic braking problem
brakes work fine normaly however I did a panice stop test yesterday on dry pavement from about 30mph and nothing happened for a split second then it seemed to slowely do the anti-lock thing. I tried it again and had to let-off quick and press down again.. Brake light never came on. Front pads have about 30K and rear drums have about 73K. Fluid level good... Do I have anti-lock problems or front pads bad or ???? Front pads are metallic replacements.
Thanks
Old Mar 1, 2005 | 01:52 PM
steve05ram360's Avatar
steve05ram360
Default RE: 2001 RAM 4X4 panic braking problem
do you have stock tires on it? I hear (not from experience) that you need to have your ABS re-caled if you have oversized tires. i have the 285's on my truck and I've had my brakes lock up on me while going into an intersection a couple of times. I pin the blame on the tires for lack of grip...
Old Mar 1, 2005 | 01:54 PM
jay6ird's Avatar
jay6ird
Yes, stock goodyear 265 w/20K on them? Truck is a 2001 Sport 5.9 auto
Old Mar 1, 2005 | 02:01 PM
steve05ram360
how many miles on the truck? you may need to have the brake system flushed... my 1st thought, there could be air and/or moisture in the system, I wouldnt think it's the pads... when you push down on the pedal, you might be compressing the fluid and trapped air in the system and that would cause it to have a delay in piston action on the calipers. if you have the original brake fluid in there, flush it and put some dot 4 fluid (synthetic stuff) and see how it is after that.
Old Mar 1, 2005 | 02:32 PM
jay6ird's Avatar
jay6ird
73K on the truck. never did anything to the brake system other than swap front pads at 35K
Old Mar 1, 2005 | 02:53 PM
steve05ram360
yeah, change the fluid. you probably have air or moisture in the system.
Old Mar 1, 2005 | 03:21 PM
jay6ird's Avatar
jay6ird
Ok, I will try that as soon as it stops snowing.... Thanks.
Old Mar 1, 2005 | 04:07 PM
steve05ram360
ok, can you post the results when your done? others might find this thread useful. -thanks
Old Apr 15, 2005 | 03:51 PM
jay6ird's Avatar
jay6ird
Truck just needed new front brake pads...
