Spark plugs really matter?
Old Mar 11, 2009 | 11:33 PM
TMS Bill's Avatar
TMS Bill
Originally Posted by JimbobT
Another +1 for the Champion recommendation. Not only do I recommend the Champion plugs, I suggest using the exact stocker plug that came in the vehicle from the factory. The list of reasons why for this is long but the simplest of them is that the manufacturer did truly do all engine testing using the stock plug equipped from the factory.
You don't think it's because Champion gives Dodge a sweet deal on plugs they buy in lots of 10,000,000?
Old Mar 12, 2009 | 11:02 AM
Ram2K1's Avatar
Ram2K1
I use the Autolite 3923's (copper) and have had no trouble with them so far. I re-gapped them after about 11K miles, and they had burned from .040 to .045 pretty consistently. The down side is that they probably need to be replaced about every 20-25K miles to stay good and fresh. The upside is that you'll spend about $12-$13 on all 8 of them at Wally World. I have heard nothing but good things about the Champion plugs, and they also make a "truck" plug with a thicker core. When I first came on this forum, the general consensus seemed to be, don't use anything except copper core on the Rams. But I say experiment...find what you like. I have tossed around the idea of using Accel race plugs next time...just need to figure out what heat range I would need. But for ease and peace of mind, I would go with the Autolite or Champion.
Old Mar 12, 2009 | 11:47 AM
Gary-L's Avatar
Gary-L
Veteran: Navy
^^ I tried the Autolites and ended up with a Misfire #5 and my mileage dropped considerably. Platinum plugs are definitely out of the question.
Old Mar 12, 2009 | 11:54 AM
Rex-TheDOGG's Avatar
Rex-TheDOGG
I'm running the factory spec Champions with no problems. Next time I will try the indexing and see if that makes a difference.
Old Mar 12, 2009 | 12:20 PM
aim4squirrels's Avatar
aim4squirrels
I will have the very unique opportunity to index all of my plugs perfectly before the heads go on.
Old Mar 12, 2009 | 12:23 PM
Laramie1997's Avatar
Laramie1997
Ok, newbie question, What all is involved with indexing the plugs, and whats the benefits?
Old Mar 12, 2009 | 12:48 PM
Rex-TheDOGG
Well, I thought it was just making sure the gap pointed down by using magic marker on the insulator.
Old Mar 12, 2009 | 01:10 PM
TMS Bill's Avatar
TMS Bill
Article on indexing here: http://www.fordmuscle.com/archives/2...gs/index.shtml
Old Mar 12, 2009 | 01:46 PM
Laramie1997
Thanks for the info. It was an interesting read.
dakotas ram's Avatar
dakotas ram
i read an article before where someone dynoed b4 and after they indexed and there was no measurable gain
