Brake light and abs light on and hazards not working
Old Mar 12, 2009 | 12:04 AM
magnum318's Avatar
magnum318
Default Brake light and abs light on and hazards not working
As the topic says. My abs and brake light on the dash stay on and my hazards wont work at all.
I think thy are related.
I have changed the sensore on the rear dif and that did nothing. Can;t come up with any codes.
94
318 auto
Old Mar 12, 2009 | 12:45 AM
TMS Bill's Avatar
TMS Bill
Check the flasher and the fuse. Not sure which one it is one '94.
Old Mar 15, 2009 | 01:05 AM
magnum318's Avatar
magnum318
checked fuses, I noticed last night my brake lights were not working. Brake light fuse was blown, swapped it out and got rid of abs and brake light but still no hazards.
Bad thing is, the abs and brake light have been on a while but just noticed I had no brake lights. Just hope I have had lights all this time.......
I need to figure out the hazards now. I have signal lights but don't know if it uses the same relay. I'll check my book and go from there, just hope it's not the switch.
Old Mar 15, 2009 | 01:31 AM
nathangfnd's Avatar
nathangfnd
i was just driving home and when i pressed on the break i looked back and couldnt tell if they were on. usually i can tell but this it didnt look right.
My break and abs light are also on so i will have to look at that
Old Mar 15, 2009 | 10:12 AM
charlie1935's Avatar
charlie1935
There is separate flashers for turn lights and four ways.
Old Mar 16, 2009 | 07:02 PM
magnum318's Avatar
magnum318
Yea just chek your fuses first. Should be labeled stop lamps or something like that. My fuse was blown but I swear I had checked the fuses b4 but that was it and the dash lights went out.
BTW: haven't gotten to check anymore. I have a cold from atving over the weekend and it's still raining here. I will get to it but don't want to stgand out in the rain checking fuses and relays.....
Old Mar 17, 2009 | 10:41 PM
magnum318's Avatar
magnum318
Guess it's the switch, i replaced the flasher and nothing so the wrok goes on...................
