98 dodge ram is not staying running
Old Mar 16, 2009 | 10:30 PM
kallen924's Avatar
kallen924
well that crank sensor was a pain in the *** to switch out, even worse it still hasnt fixed my problem starts and runs for about 5 seconds and then dies. Now i have no idea what to do have ran the scanner again and its not reading any codes from the computer. does anybody have any other ideas to what it is. Im about worn out on this thing.
Old Mar 16, 2009 | 10:32 PM
wjxavier's Avatar
wjxavier
did you replace the TPS and IAC?
Old Mar 16, 2009 | 10:59 PM
TMS Bill's Avatar
TMS Bill
Will it stay running if you keep your foot in it?
edit: D'oh !! Should read farther back. Note to self ... read farther back.
Old Mar 16, 2009 | 11:23 PM
Bigdodge98's Avatar
Bigdodge98
The only other things i can think of is the coil or a problem in your distributor
Old Mar 17, 2009 | 04:59 AM
zman17's Avatar
zman17
Retired Moderator - RIP
Just because you can hear the fuel pump running does not mean it is providing the correct amount of pressure. You should check it with a gauge. Also maybe the ASD relay is worth replacing.
Old Mar 17, 2009 | 11:26 AM
kallen924's Avatar
kallen924
I have replaced both of the ones on the throttle body, and no it will not stay running. It just dies out, runs the same amount of time wheater you let it idle or try to keep it running. The fuel rails are keeping pressure. And I would think if it were the distributor that it would back fire or something, motor runs fine untill it dies 5 seconds later.
Old Mar 17, 2009 | 05:27 PM
zman17's Avatar
zman17
How do you know you have the right amount of pressure? And how do you know that when it dies it has the right amount of pressure? Check it the right way and eliminate it from the fray.
