quick axle question
Old Mar 14, 2009 | 01:55 PM
olyelr's Avatar
olyelr
Originally Posted by nickkendall
you are talking about the collar that slides to connect the 2 shafts?
i have that taken out also so the housing is completely empty other then pumpkin and i still can't get the first shaft to slide in all the way
Ahhhh. Hmmmmm. Have you removed the diff cover? If not, remove that so you can see what the heck is going on. Maybe the shaft isn't perfectly lined up with the splines to allow it to slide in (although I am sure you twisted it around a zillion times already), but that will allow you to see whats appening anyway.
Old Mar 15, 2009 | 09:50 PM
nickkendall's Avatar
nickkendall
now i got the axles installed i noticed there is a bearing that the half shaft goes into and i noticed mine is bad..what is it called and how do you get it out and a new one in place?
Old Mar 15, 2009 | 10:41 PM
dhvaughan's Avatar
dhvaughan
this place has all the front end components. here's your bushing, bearing, and seal.
http://www.riversidegear.com/categor...oduct-821.html
