Replaced the TPS
Old Mar 15, 2009 | 05:19 PM
RAZRAM's Avatar
RAZRAM
Default Replaced the TPS
so i went to schucks and spend $55 for a new TPS and installed the thing then reset the PCM and then started up the truck and the problem is still there. I figured out that the rpms fall at a normal rate if it isnt reved to 2,000. If it reved up past 2000 then it falls normal until it hits 2000 (and hovers there for a sec) then it drops back down normaly. PLEASE HELP!
Old Mar 15, 2009 | 06:26 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Odds are it's the IAC. Unless you replaced that already.
Old Mar 15, 2009 | 06:31 PM
mr.318's Avatar
mr.318
Why did yo replace the t.p.s.? did it show up on the fault codes? Is the check engine lite on ?
Old Mar 15, 2009 | 06:36 PM
zman17's Avatar
zman17
The CEL won't go on for either of those things, (TPS or IAC).
Old Mar 15, 2009 | 09:24 PM
mr.318's Avatar
mr.318
I've seen em show the the t.p.s. before code #24
Old Mar 15, 2009 | 11:59 PM
RAZRAM's Avatar
RAZRAM
i havent replaced the IAC. How much do those go for? i have searched everywhere online and cannot find anything about them.
Old Mar 16, 2009 | 04:31 AM
zman17's Avatar
zman17
Try cleaning it and the bore it goes into on the back of the TB first.
Old Mar 16, 2009 | 05:55 AM
dhvaughan's Avatar
dhvaughan
common part available at any local parts store. about $45-55.
replaces in 5 min, 2 #25 torx, don't forget the o-ring.
and be sure and clean out the pintle cavity, sometimes it gets gunked up.
don't push, pull, or twist on the pintle, you will break it.
http://www.rockauto.com/catalog/x,ca...,parttype,6072
Old Mar 16, 2009 | 03:55 PM
mr.318's Avatar
mr.318
But i agree with zman try cleaning it first,You never answered my ? is your c.e.l.on
