finding gears, need some help!
Old Mar 16, 2009 | 06:16 PM
aim4squirrels's Avatar
aim4squirrels
Default finding gears, need some help!
So I pulled the VB today and installed the Sonnax kit, at least as much as I could without pulling the VB all apart. Not a fun job. I'll post pics up shortly, but I have a small problem that I need solved first:
When I cycle thru the gears on the shifter column, there's a firm transition from Park to Reverse to Neutral. But if I shift to drive, it's soft and I have to actually pass "D" just a bit and go back on the indicator. What's more, it gets softer as I go past D, 2, 1 and I'm not even getting 1st gear only to engage even though I've gone all the way past 1 on the indicator.
I was extremely meticulous on the VB rebuild so I don't think it's that. I'm not sure if the linkage on the outside is adjustable any, so if somebody knows, let's here it.
Old Mar 16, 2009 | 07:23 PM
olyelr's Avatar
olyelr
Yep, it is adjustable from under the truck. When I installed my body lift, all I did was adjust it from down there instead of welding in a 3" rod.
I know exactly what you are talking about though... my truck shifts the exact same way. By the time it gets down to 2nd and 1st, the indicator is a little off and it doesn't feel like the shifter itself is actually locked in gear. I would adjust it, but I am worried the adjustment screw is seized in its place
Old Mar 16, 2009 | 10:30 PM
aim4squirrels
got it! I had some play (only about 1/4") where the linkage connected to the VB. The throttle linkage was not fully seated atop the detent post.
Thanks for the help, Olyelr. I did'nt have to fiddle with the adjustment screw.
Old Mar 16, 2009 | 10:34 PM
aim4squirrels
According to the FSM that screw is only 100 inch/lbs tight at factory spec. I'd get after it, unless you've heard some horror stories over at PS about it.
Old Mar 16, 2009 | 11:34 PM
olyelr's Avatar
olyelr
I have not heard anything bad about it before. But, I haven't actually stuck my head up there and looked at it since I put the body lift on over 9 years ago... and I can remember trying to adjust the one on my dads truck a few years back and there was no way it was gonna loosen without breaking. Gotta love all the salt they spread on the roads...
Good to hear you got yours fixed. I was kinda thinking it would be odd that you would have to adjust that when you didn't do anything to it in the first place.
