4x4 Lever
Old Mar 16, 2009 | 06:41 PM
LegendKiller89's Avatar
LegendKiller89
Default 4x4 Lever
Hey guys, I bought a new cover for my 4wd lever. How does the **** come off? Twist off or pull off? I didn't wanna go yanking and booger something up. Anyone who can help thanks alot!
Old Mar 16, 2009 | 07:18 PM
94Beater's Avatar
94Beater
Use small flat screwriver to pop the center cap out.
Inside you'll find a nut (12mm or 14mm - I'm not sure now) unscrew the jam nut and then unscrew the ****.
Old Mar 16, 2009 | 07:31 PM
PurplDodge's Avatar
PurplDodge
Boot or ****?
**** REMOVAL:
Shove a screwdriver in the center cap and remove. Take a 9/16'' wrench and remove the blue nut. Install is reverse.
BOOT REMOVAL:
Remove Shift ****^. Pry around the base of the boot and remove.
Old Mar 16, 2009 | 09:17 PM
MAJohns's Avatar
MAJohns
kool i just screw my **** on and off!
