SO UNDECIDED Lift kit or tires
Old Mar 20, 2009 | 07:19 PM
  #21
pavement_hater's Avatar
pavement_hater
You say you need tires bad but then go on to say you think you can get another year out of them. So which is it? If they can last another year then you really don't need them that bad. Its really simple. 2/32nds of tread or less then replace.
Old Mar 20, 2009 | 08:41 PM
  #22
lastrights's Avatar
lastrights
that alot of miles to start throwing money at it
Old Mar 20, 2009 | 11:03 PM
  #23
05DodgeRamHemi's Avatar
05DodgeRamHemi
I think you should have your trail arm problem fixed, and your trackbar relocation addressed.
Also, what are your plans for a new lift? I recall you saying you weren't happy with your coil spacer; you said something about it clunking when you stop? If you bought a new lift, would you try to go higher than it is, or just a different set-up? To me, changing the lift is fine; but is something that can wait.
If it were me, I'd fix my problems first. If you think you have some time left with your goodyears, then addressing the other issues should be dealt with. Then you can treat yourself to a new set of tires when everything is taken care of.
Old Mar 21, 2009 | 08:32 AM
  #24
2damnyankee's Avatar
2damnyankee
yes you are rite i dont like the spacers and they do clunk or it could be the trac bar . or the trailing arm bushings . iether way it needs to be fixed
Old Mar 21, 2009 | 08:38 AM
  #25
2damnyankee
Ok i ordered the new tires they are master craft from cooper. I dont drive it as often so if they wear fast, but i get at least 3 years out of them i can live with it. also order the hughes plenum fix kit. and if top gun customz ever answers there phone i will order new adjustable trailing arm's
emailed don at thuran's fab and going to order his adjustable trac bar for 0-3 in
Old Mar 21, 2009 | 08:46 AM
  #26
gipperkid's Avatar
gipperkid
Yeah, I ordered my 3" Rough Country lift from Top Gun Customz. Two weeks passed and no email for shipping. When I called, l was always on hold forever and never got an answer. Finally after three weeks I find out part of the kit is on back order from Rough Country. But a rep actually did call to tell me that. There are people are very nice, but there communication skills are lacking.
