This may sound stupid, but...
Old Mar 20, 2009 | 09:57 PM
VOATMJ1's Avatar
VOATMJ1
Default This may sound stupid, but...
How in the hell do you change the front turn signal bulb in a 01 Sport? The socket is not exposed like the headlight bulbs are and the maintenance manual is no help. Do you have to take half the front fender off to get to it?
Old Mar 20, 2009 | 10:06 PM
dodge15004x45.9's Avatar
dodge15004x45.9
my non-sport there's one screw on the side under the light you take that off than twist and yr done.
Old Mar 20, 2009 | 10:17 PM
VOATMJ1's Avatar
VOATMJ1
There is metal panel right next to the headlight bulb from inside of the engine, (covering the spot where you would normally twist and pull the turn signal bulb) and looking underneath the inner fender wheel well is in place. Impossible to access. I never seen anything like this before!
Old Mar 20, 2009 | 10:20 PM
VOATMJ1's Avatar
VOATMJ1
Wait, it just registered what you said, you mean the whole lens assembly twists off?
Old Mar 20, 2009 | 10:42 PM
01dabram20's Avatar
01dabram20
One screw holds it on on the side.
Old Mar 20, 2009 | 10:51 PM
dodge15004x45.9
which are you replacing headlights or turn single?
Old Mar 20, 2009 | 10:59 PM
dodge15004x45.9
look at this.
http://209.200.64.237/images/auto/4958.jpg
See that tab under that yellow part of the light that is held on by a screw undo that and it will come out. Than turn the light head and the bulb should come out.
Old Mar 20, 2009 | 11:02 PM
dodge15004x45.9
or this
http://en.allexperts.com/q/Dodge-Rep...nal-repair.htm
Old Mar 21, 2009 | 01:21 AM
J415's Avatar
J415
The best way to figure out how something is put together or where bolts/srews go is to go on the internet and do a Google image search. It'll show you different angles so you have an idea as to how it goes together. Thats what I do, but it's just a suggestion.
Old Mar 21, 2009 | 08:17 AM
VOATMJ1's Avatar
VOATMJ1
Thanks for all the direction. I think (maybe) that I got it now. I will go out and try it today, I just hope I don't break something in the task!
