2000 Ram 1500 steering knuckle/spindle
Old Mar 21, 2009 | 10:47 AM
gipperkid's Avatar
gipperkid
Default 2000 Ram 1500 steering knuckle/spindle
I need help. I am working on this 2000 Ram 1500 4x4. I'm the guy who had the transmission and transfer case both broken in a wreck. Well the driver spindle is broken where the tie rod end attaches. For some reason the book states only 2000-2001 will interchange. Does anyone know the difference of why I could not use a 1994-2001 spindle?
Old Mar 21, 2009 | 11:07 AM
dhvaughan's Avatar
dhvaughan
it probably the difference in the brake caliper. early models were smaller, single piston (sucked) and later models were larger, double piston (better).
Old Mar 21, 2009 | 12:01 PM
gipperkid's Avatar
gipperkid
I don't know if it's the caliper, because there is a 1996 and has dual pistonc calipers.
Old Mar 21, 2009 | 12:04 PM
dhvaughan's Avatar
dhvaughan
is the 96 dual a 1500 or a 2500/3500 ? those are different too.
Old Mar 21, 2009 | 12:09 PM
gipperkid's Avatar
gipperkid
It's a 1500. But the hub bearing my different also.
