clicking noise
Old Mar 22, 2009 | 10:08 PM
wesley11's Avatar
wesley11
Default clicking noise
Hey guys, I have a strange clicking noise coming from my front end when I turn and apply the brakes. Doesnt happen when I hit bumps or any other time. I have a 97 4x4 with a 3" lift. Any ideas? Thanks in advance.
Old Mar 23, 2009 | 01:29 AM
jasonw's Avatar
jasonw
Site Moderator
U-Joints and/or ball joints should get checked. Or perhaps something is rubbing something. What size tires do you have?
Old Mar 23, 2009 | 02:19 AM
01 silver ram 1500's Avatar
01 silver ram 1500
yea its most likely u joints
Old Mar 23, 2009 | 12:50 PM
dblj16380's Avatar
dblj16380
Ha, I've got the same noise. I know for a fact that mine is the u-joint because I bent the stub shaft yoke when I put the last u-joint it. If you really wanna make some noise then throw it in 4wd. That thing will be louder than ever.
By the way, just so no one is concerned, I parked the truck and ordered the new shaft from the dealership so I don't do damage to my front driveshaft.
Anyways, to check if its your u-joints, just jump under the truck and give your front driveshafts a good shake back and forth and up and down along the axis' of the u-joint. If you have any play at all then your u-joint are either bad or on their way out.
Old Mar 24, 2009 | 09:51 PM
wesley11's Avatar
wesley11
I just checked the front drive shaft, and the u-joints have no slop in them. The sound happens when I push the brakes and turn a corner.Would not be surprised if it were the ball joints. I dont think any thing is rubbing, so I am not sure what it is. My tire size is 295 75 r16. Any other ideas? It is driving me nuts. Thanks
Old Mar 24, 2009 | 09:55 PM
hutch1973's Avatar
hutch1973
How about the front axle shaft. Look at the knuckle behind your front hub area. Last year those u-joints when out on mine and did something similar.
Old Mar 24, 2009 | 10:25 PM
TMS Bill's Avatar
TMS Bill
Not the driveshaft u-joints ... the axle u-joints. The front driveshaft doesn't move unless you're in 4wd.
Old Mar 24, 2009 | 10:52 PM
wesley11's Avatar
wesley11
Ah, that makes more sense.I will check those in the morning. Can I do these myself?
Old Mar 24, 2009 | 11:01 PM
wesley11's Avatar
wesley11
I went out and moved the u-joints on the front axle, and there is a very little clanking when wiggled. Doesnt look like an easy repair to me. Anyone done these?
Old Mar 24, 2009 | 11:09 PM
aim4squirrels's Avatar
aim4squirrels
cv joint?
