HI Low Light combo??????
Old Mar 24, 2009 | 02:10 AM
cwbykeep's Avatar
cwbykeep
Exclamation HI Low Light combo??????
Ok so still being knew to the whole mod world i am looking for what ever the thing is that makes it so you high beams are on at the same time as your low beams. also will my fog lights stay on while this ''thing'' is in play? also how hard is it to install on my own.
thanks in advance and hope you all can help
Old Mar 24, 2009 | 02:20 AM
Viper37's Avatar
Viper37
You can only do this with a sport, which I don't think you have. You can keep your fog lights on by jumpering the positive side of the fog light's to the high beam wire. However I'd completely rewire the headlights using a pair of Relays.
Old Mar 24, 2009 | 03:36 AM
TMS Bill's Avatar
TMS Bill
http://dodgeram.org/tech/mods/electric/headlight.htm
Old Mar 24, 2009 | 08:49 AM
jasonw's Avatar
jasonw
Site Moderator
+1 for what Viper said.
Even if you can do this with a regular Ram (non-Sport), I wouldn't. Keeping both elements inside the bulb on at the same time for any period of time will drastically shorten the bulb life, they aren't designed for that. Trust me, I accidentally had it wired that way for a while (connected the wrong wires due to faulty info I got off the net).
A Sport edition with multiple bulbs, though, wouldn't be much of a problem. Just do it the way Viper mentioned, with relays.
