towing
Old Mar 25, 2009 | 01:50 PM
  #21
dodge15004x45.9's Avatar
dodge15004x45.9
IDK if it will help but I'm watching trick my truck and they had a 2500 dodge 4x4 in there and I think its gas they put 2 rear axles on it and put A 16,000 5th wheel in it.
Old Mar 25, 2009 | 01:53 PM
  #22
Cereal Killer's Avatar
Cereal Killer
2 rear axels kick ***...
Old Mar 25, 2009 | 02:29 PM
  #23
dodge15004x45.9
yea I know I have no plans to do that.
Old Mar 25, 2009 | 08:14 PM
  #24
Gotta feed them horses's Avatar
if it's a v1o it is 10,000 on the hitch and I have had 20,000 on the 5th wheel but I would say 15,000 is safe.
Old Mar 25, 2009 | 08:22 PM
  #25
Cereal Killer
I think you're safe up to a D11
Old Mar 25, 2009 | 08:23 PM
  #26
dodge15004x45.9
Dam i think i got a chubby for that one!
Old Mar 25, 2009 | 09:23 PM
  #27
jasonw's Avatar
jasonw
Site Moderator
Livinterror:
The maximum trailer weight the 2500 is rated for with the 5.9L V8...
4x2 Regular Cab - 8900 lbs
4x2 Quad Cab - 8600 lbs
4x4 Regular Cab - 8400 lbs
4x4 Quad Cab - 8150 lbs
Purpl:
The maximum trailer weight the 1500 is rated for with the 5.2L V8 or the 5.9L V8...
4x2 Regular Cab - 7950 lbs
4x2 Club/Quad Cab - 7500 lbs
4x4 Regular Cab - 7600 lbs
4x4 Club/Quad Cab - 7200 lbs
Old Mar 25, 2009 | 09:54 PM
  #28
PurplDodge's Avatar
PurplDodge
Guess I will have to fully box my frame!
Old Mar 25, 2009 | 10:08 PM
  #29
95MaroonMonster's Avatar
95MaroonMonster
lol, purple, your truck will be fine, the frames on the rams are almost identical if i remember right, the reason 2500s are able to carry more weight is the full floating D60 rear axle, compared to our semi floating 9.25 rear
Old Mar 25, 2009 | 10:17 PM
  #30
Cereal Killer
Yeah the only difference between the 1500, and 2500 with the 5.9 is the Dana 60 rear end (front end too in the 4x4). It even has the same 2.5" wide leafs as the 1500s. The V-10 and cummins got 3" wide leaf springs. oh and the lift blocks in the 2500s are about 2" taller.
The engine, transmission, and transfercase (in the 4x4) are all identical. Wouldn't it have been nice if they'd have just put Dana 60s in the 1500, and not bothered with a V8 option in the 2500s?
