electric fan
Old Mar 30, 2009 | 03:22 PM
  #51
dakotas ram's Avatar
dakotas ram
alright i got the fan and put it on, got a controller.......i wired it up like the diagram at the bottom of the page and it works good with the engine off, but with it on it blows a 30 amp fuse......im using 16ga wire that came with the controller and i think my relay is 30 also.....anyone know what im doin wrong? too light of wire?.....any suggestions are welcome.....gotta go to work, so i cant get back on here until 11....thanks
Old Mar 31, 2009 | 01:13 AM
  #52
dakotas ram
ooops, heres how i wired it all the way at the bottom.....any ideas as to why it blows fuses?....im gonna try bigger wire tomorrow and maybe bigger relay
http://www.mustangmotorsport.com/fan.html
Old Mar 31, 2009 | 10:09 AM
  #53
mcss8541's Avatar
mcss8541
Originally Posted by Jpnorris87
Hey, Im looking to do this when I get back up north. Got one more winter to get thru in Fairbanks, AK. Did anybody notice a mpg increase? I can see maybe 1to2 mpg and maybe a slightly quicker throttle response.....but what have you guys noticed?
i saw a 3mpg increase with big time increase in torque and hp on my set up.
Old Mar 31, 2009 | 10:12 AM
  #54
mcss8541's Avatar
mcss8541
what type of fan did you get?
Old Mar 31, 2009 | 10:14 AM
  #55
mcss8541's Avatar
mcss8541
never mind i saw your link. I didn't have any worries with my flex-a-lite setup, no blown fuses, ran perfect the first time. all i had to do was set my thermostat.
Old Mar 31, 2009 | 10:54 AM
  #56
Jase's Avatar
Jase
make sure all your connections are good (no exposed wire), and if they are, then double check you got the relay connected to all the right wires, and if still good, I guess try a different gauge wire...
Old Mar 31, 2009 | 12:03 PM
  #57
dakotas ram
i got a mark viii fan....its pretty awesome.....i think i got it figured out...i got a 40 amp relay and a 40 amp fuse and its doin good, from what i read, when the fan kicks on, the amps spike up to around 100 for a second and then settle back down to around 35....it suggested using a 75 amp relay, but i couldnt find one....gonna redo most of my wire with 10 ga later
Old Mar 31, 2009 | 12:16 PM
  #58
dodge15004x45.9's Avatar
dodge15004x45.9
pics?
Old Mar 31, 2009 | 01:00 PM
  #59
JBs DAK's Avatar
JBs DAK
Napa has a 75 Boush amp relay,.. I used a mega-fuse. (The kind that the wire bolts
to each side of the fuse &, the fuse is in it's own holder). The spike at start-up is what's
killing the 30 amp.
  #60
mcss8541's Avatar
mcss8541
cool glad you got it done. i'll try to get pics of my setup as well. still figuring out the Blackberry Storm cell phone camera to computer thing.
