Old Aug 6, 2015, 01:04 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Lighting
Print Wikipost
Leaking roof. Dome light removal?
Old Mar 26, 2009 | 03:43 PM
mtbnathan's Avatar
mtbnathan
Default Leaking roof. Dome light removal?
Hi. Could use some instruction on how to remove the dome light. Does anyone know how to remove it to investigate a leak in the roof? I have water above the drivers seat area.
I have read on here that it might be the bed light gasket/seal. My truck also has a service light plug in the center of the roof. I will check that out; order a new seal/gasket, or silicone the plug.
My headliner is already shot, moldy and sagging. I will be replacing it, just as soon as I feel I've repaired the leak!
Thanks for the help.
Old Mar 26, 2009 | 04:35 PM
EndIsNear's Avatar
EndIsNear
To remove the Dome light, if its the same as mine, use a small screwdriver and pry the driver side clear plastic until it pops out. The other side acts like a hinge, so pull the clear down a little and pull the housing downwards on the passenger side. It should slide out then. I would think it was the third brake light seal too...
