stereo
Old Mar 29, 2009 | 05:45 PM
swiater's Avatar
swiater
Default stereo
if im putting an aftermarket stereo system in the truck is there anything special i need to know when installing it due to the amplified speakers?
Old Mar 29, 2009 | 06:21 PM
hutch1973's Avatar
hutch1973
Assuming you are getting a wiring harness kit for it? From what I recall (did this a year ago) I had to attach the power antenna/remote wire from the new stereo to the 'amp' lead in the wiring harness and it worked fine.
Old Mar 29, 2009 | 07:09 PM
swiater's Avatar
swiater
do you know if the stereo needs to have a built-in amplifier?
Old Mar 29, 2009 | 07:11 PM
hutch1973's Avatar
hutch1973
If you are using the factory infinity system, no you don't need a head unit with the factory amplifier. Just hook up the remote wire correctly and it will utilize the factory amplifier. If I remember correctly, I didn't hook the wire up initially, and had next to nothing for sound, so you should know pretty quickly if you did it right or not.
Old Mar 29, 2009 | 07:18 PM
swiater's Avatar
swiater
thanks man
Old Mar 29, 2009 | 07:33 PM
divetruck's Avatar
divetruck
Its the BLUE WIRE!
