Is it the transmission?????
Old Mar 31, 2009 | 08:18 PM
nathangfnd's Avatar
nathangfnd
not really sure but it may be spark plugs
I had somewhat the same problem a few months ago when i was getting on the highway, it kinda jumped a little, but i let off and and it seemed normal from there but it soon said check engine and i had 2nd cylinder misfire.
Just something to possibly check
Old Mar 31, 2009 | 08:33 PM
TMS Bill's Avatar
TMS Bill
Originally Posted by mcss8541
I went to look at it and seems to be in place however, not knowing what I know now, I attempted to remove this cable from the bracket when I removed the fuel rail and had it partially undone before I said screw it and snapped it back into place because it was a beeyatch to take off. I do notice I have some firm shifts and the the transmission that's in there now was not the original. Burned mine up towing it without disenaging the transfer case, anyway I guess this weekend I can fart around with it and try to make some adjustments. Thanks!
I was just wanting to know if the clip was loose ... if it snapped together ... you should be in good shape. When it's loose, the cable adjustment can drift, messing up your shift points.
Old Mar 31, 2009 | 08:49 PM
mcss8541's Avatar
mcss8541
K thanks!
Old Mar 31, 2009 | 08:50 PM
mcss8541's Avatar
mcss8541
Yeah Nathan I have the same issue as well since my CEL keeps coming on after I reset it I just left it on. I definitely have some misfire issues I have to take care of though.
