Installed new headers now something gone wrong
Old Apr 24, 2009 | 07:46 AM
  #51
mopowar's Avatar
mopowar
-32 is as far as it goes and you are right, it means that the pcm is pulling fuel. When your stft hits -32 you will get a rich code. I would say it is either the fuel driver in the pcm, the pressure regulator, or sticking injectors. I don't know all that much about how the cali pcm works, but I would think if it were one injector sticking that just one bank would be pulling fuel. Excessive fuel pressure would make both banks go rich. I would check that first (while the problem is occuring). Like I said before, you can check the injectors with a mechanic's stethascope (~$8.00). It is pretty simple. You just touch the end to each injector and listen for a clicking noise. If you touch it to an injector and don't hear clicking, then that injector is either sticking open or not opening. Checking the PCM- only one option for that, and I would tell them that under no circumstances do you want any TSB updates installed on thier.
Also: Check the ground strap going from the pcm to the firewall and make sure the connections are tight and clean. Also try swapping the fuel pump relay with another one.
Old Apr 24, 2009 | 09:12 AM
  #52
ICEMAN_CH's Avatar
ICEMAN_CH
Here is the recoreded data. It showing the fuel being cut from one side but, I could sworn that I've seen it cut both sides. I'm going to go out and record it again. IT was funny as hell because it started to do it so I tried to hook up the scanner. While I was hooking the scanner in I could hear a hissing noise that kept getting louder and louder. Well ignored and started the recording man was the truck pissed off. it was backfireing and sputtering like crazy. Well when I got onto the road whenever I let go of the gas the truck would continue to speed up and thats when I relized that that hissing noise was the IAC opening up and now that it was opened all of the way the truck was driving stupid. It took the whole drive home for that damn thing to reset. Anyways here is that data. I'm going to take it to a mechanic feind off mine so that we can look through the fuel system.
Recorded Data
MIL STATUS ON
ABSLT TPS % 12.9
ENG SPEED RPM 527
CALC LOAD % 8.6
MAP KPA 76
COOLANT F 168
IAT F 123
IGN ADVANCE DE 24.0
ST FTRM1 % -33.0
LT FTRM1 % 0.8
ST FTRM2 % 0.0
LT FTRM2 % 0.8
VEH SPEED MPH 0
FUEL SYS 1 CLSD
FUEL SYS 2 OPEN
O2S11 V 0.760
ST FTRM11 % -33.0
O2S12 V 1.000
O2S21 V 1.000
ST FTRM21 % 0.0
O2S22 V 1.000
PTO STATUS DISEN
OBD2 STAT CA
Frame -5 Time -30.4
MIL STATUS ON
ABSLT TPS % 12.9
ENG SPEED RPM 591
CALC LOAD % 7.4
MAP KPA 74
COOLANT F 170
IAT F 123
IGN ADVANCE DE 6.0
ST FTRM1 % -33.0
LT FTRM1 % 0.8
ST FTRM2 % 0.0
LT FTRM2 % 0.8
VEH SPEED MPH 0
FUEL SYS 1 CLSD
FUEL SYS 2 OPEN
O2S11 V 0.760
ST FTRM11 % -33.0
O2S12 V 1.000
O2S21 V 1.000
ST FTRM21 % 0.0
O2S22 V 1.000
PTO STATUS DISEN
OBD2 STAT CA
Frame -4 Time -24.4
MIL STATUS ON
ABSLT TPS % 12.9
ENG SPEED RPM 684
CALC LOAD % 9.0
MAP KPA 76
COOLANT F 170
IAT F 123
IGN ADVANCE DE 24.0
ST FTRM1 % -33.0
LT FTRM1 % 0.8
ST FTRM2 % 0.0
LT FTRM2 % 0.8
VEH SPEED MPH 0
FUEL SYS 1 CLSD
FUEL SYS 2 OPEN
O2S11 V 0.760
ST FTRM11 % -33.0
O2S12 V 1.000
O2S21 V 1.000
ST FTRM21 % 0.0
O2S22 V 1.000
PTO STATUS DISEN
OBD2 STAT CA
Frame -3 Time -18.3
MIL STATUS ON
ABSLT TPS % 12.9
ENG SPEED RPM 535
CALC LOAD % 9.0
MAP KPA 75
COOLANT F 170
IAT F 123
IGN ADVANCE DE 10.5
ST FTRM1 % -33.0
LT FTRM1 % 0.8
ST FTRM2 % 0.0
LT FTRM2 % 0.8
VEH SPEED MPH 0
FUEL SYS 1 CLSD
FUEL SYS 2 OPEN
O2S11 V 0.740
ST FTRM11 % -33.0
O2S12 V 1.000
O2S21 V 1.260
ST FTRM21 % 0.0
O2S22 V 1.000
PTO STATUS DISEN
OBD2 STAT CA
Frame -2 Time -12.2
MIL STATUS ON
ABSLT TPS % 12.9
ENG SPEED RPM 621
CALC LOAD % 7.4
MAP KPA 75
COOLANT F 172
IAT F 123
IGN ADVANCE DE 6.0
ST FTRM1 % -33.0
LT FTRM1 % 0.8
ST FTRM2 % 0.0
LT FTRM2 % 0.8
VEH SPEED MPH 0
FUEL SYS 1 CLSD
FUEL SYS 2 OPEN
O2S11 V 0.740
ST FTRM11 % -33.0
O2S12 V 1.000
O2S21 V 1.220
ST FTRM21 % 0.0
O2S22 V 1.000
PTO STATUS DISEN
OBD2 STAT CA
Frame -1 Time -6.2
MIL STATUS ON
ABSLT TPS % 12.9
ENG SPEED RPM 697
CALC LOAD % 7.4
MAP KPA 74
COOLANT F 172
IAT F 123
IGN ADVANCE DE 21.0
ST FTRM1 % -33.0
LT FTRM1 % 0.8
ST FTRM2 % 0.0
LT FTRM2 % 0.8
VEH SPEED MPH 0
FUEL SYS 1 CLSD
FUEL SYS 2 OPEN
O2S11 V 0.740
ST FTRM11 % -33.0
O2S12 V 1.000
O2S21 V 1.180
ST FTRM21 % 0.0
O2S22 V 1.000
PTO STATUS DISEN
OBD2 STAT CA
Frame 0 Time 0.0
MIL STATUS ON
ABSLT TPS % 12.9
ENG SPEED RPM 548
CALC LOAD % 9.8
MAP KPA 75
COOLANT F 172
IAT F 123
IGN ADVANCE DE 19.5
ST FTRM1 % -33.0
LT FTRM1 % 0.8
ST FTRM2 % 0.0
LT FTRM2 % 6.2
VEH SPEED MPH 0
FUEL SYS 1 CLSD
FUEL SYS 2 OPEN
O2S11 V 0.740
ST FTRM11 % -33.0
O2S12 V 1.000
O2S21 V 1.240
ST FTRM21 % 0.0
O2S22 V 1.000
PTO STATUS DISEN
OBD2 STAT CA
Frame 1 Time 6.2
MIL STATUS ON
ABSLT TPS % 14.5
ENG SPEED RPM 854
CALC LOAD % 9.0
MAP KPA 70
COOLANT F 172
IAT F 122
IGN ADVANCE DE 22.5
ST FTRM1 % -33.0
LT FTRM1 % 7.0
ST FTRM2 % 0.0
LT FTRM2 % 6.2
VEH SPEED MPH 0
FUEL SYS 1 CLSD
FUEL SYS 2 OPEN
O2S11 V 0.740
ST FTRM11 % -33.0
O2S12 V 1.000
O2S21 V 1.140
ST FTRM21 % 0.0
O2S22 V 1.000
PTO STATUS DISEN
OBD2 STAT CA
Frame 2 Time 12.3
MIL STATUS ON
ABSLT TPS % 25.8
ENG SPEED RPM 966
CALC LOAD % 14.9
MAP KPA 89
COOLANT F 172
IAT F 120
IGN ADVANCE DE 24.0
ST FTRM1 % -33.0
LT FTRM1 % 7.0
ST FTRM2 % 0.0
LT FTRM2 % 5.4
VEH SPEED MPH 6
FUEL SYS 1 CLSD
FUEL SYS 2 OPEN
O2S11 V 0.720
ST FTRM11 % -33.0
O2S12 V 1.000
O2S21 V 1.160
ST FTRM21 % 0.0
O2S22 V 1.000
PTO STATUS DISEN
OBD2 STAT CA
Frame 3 Time 18.4
MIL STATUS ON
ABSLT TPS % 26.2
ENG SPEED RPM 1023
CALC LOAD % 17.6
MAP KPA 87
COOLANT F 174
IAT F 123
IGN ADVANCE DE 29.0
ST FTRM1 % -33.0
LT FTRM1 % 4.6
ST FTRM2 % -9.2
LT FTRM2 % 3.9
VEH SPEED MPH 18
FUEL SYS 1 CLSD
FUEL SYS 2 CLSD
O2S11 V 0.680
ST FTRM11 % -33.0
O2S12 V 1.000
O2S21 V 0.780
ST FTRM21 % -18.6
O2S22 V 1.000
PTO STATUS DISEN
OBD2 STAT CA
Frame 4 Time 24.4
MIL STATUS ON
ABSLT TPS % 26.2
ENG SPEED RPM 1480
CALC LOAD % 20.7
MAP KPA 79
COOLANT F 174
IAT F 118
IGN ADVANCE DE 16.0
ST FTRM1 % -33.0
LT FTRM1 % 0.7
ST FTRM2 % -24.3
LT FTRM2 % 0.7
VEH SPEED MPH 21
FUEL SYS 1 CLSD
FUEL SYS 2 CLSD
O2S11 V 0.600
ST FTRM11 % -33.0
O2S12 V 1.000
O2S21 V 0.560
ST FTRM21 % -25.8
O2S22 V 1.000
PTO STATUS DISEN
OBD2 STAT CA
Frame 5 Time 30.5
MIL STATUS ON
ABSLT TPS % 26.2
ENG SPEED RPM 1033
CALC LOAD % 16.0
MAP KPA 90
COOLANT F 176
IAT F 123
IGN ADVANCE DE 12.5
ST FTRM1 % -33.0
LT FTRM1 % 5.4
ST FTRM2 % -26.0
LT FTRM2 % 5.4
VEH SPEED MPH 19
FUEL SYS 1 CLSD
FUEL SYS 2 CLSD
O2S11 V 0.560
ST FTRM11 % -33.0
O2S12 V 1.000
O2S21 V 0.460
ST FTRM21 % 0.0
O2S22 V 1.000
PTO STATUS DISEN
OBD2 STAT CA
Frame 6 Time 36.5
MIL STATUS ON
ABSLT TPS % 73.3
ENG SPEED RPM 3619
CALC LOAD % 65.0
MAP KPA 93
COOLANT F 177
IAT F 113
IGN ADVANCE DE 31.5
ST FTRM1 % 0.0
LT FTRM1 % 0.8
ST FTRM2 % -2.2
LT FTRM2 % 0.8
VEH SPEED MPH 38
FUEL SYS 1 OPEN1
FUEL SYS 2 OPEN1
O2S11 V 1.000
ST FTRM11 % -9.2
O2S12 V 1.000
O2S21 V 1.020
ST FTRM21 % -12.1
O2S22 V 1.000
PTO STATUS DISEN
OBD2 STAT CA
Frame 7 Time 42.6
MIL STATUS ON
ABSLT TPS % 27.4
ENG SPEED RPM 2036
CALC LOAD % 26.6
MAP KPA 73
COOLANT F 179
IAT F 116
IGN ADVANCE DE 26.0
ST FTRM1 % -9.2
LT FTRM1 % 6.2
ST FTRM2 % -4.9
LT FTRM2 % 6.2
VEH SPEED MPH 39
FUEL SYS 1 CLSD
FUEL SYS 2 CLSD
O2S11 V 0.420
ST FTRM11 % -7.7
O2S12 V 1.000
O2S21 V 1.140
ST FTRM21 % -8.0
O2S22 V 1.000
PTO STATUS DISEN
OBD2 STAT CA
Frame 8 Time 48.8
MIL STATUS ON
ABSLT TPS % 12.9
ENG SPEED RPM 1366
CALC LOAD % 10.5
MAP KPA 42
COOLANT F 183
IAT F 116
IGN ADVANCE DE 16.0
ST FTRM1 % -4.9
LT FTRM1 % 0.7
ST FTRM2 % -2.2
LT FTRM2 % 0.7
VEH SPEED MPH 41
FUEL SYS 1 CLSD
FUEL SYS 2 CLSD
O2S11 V 1.140
ST FTRM11 % -7.7
O2S12 V 1.000
O2S21 V 0.360
ST FTRM21 % -9.2
O2S22 V 1.000
PTO STATUS DISEN
OBD2 STAT CA
Frame 9 Time 54.9
MIL STATUS ON
ABSLT TPS % 23.9
ENG SPEED RPM 1630
CALC LOAD % 20.3
MAP KPA 68
COOLANT F 185
IAT F 116
IGN ADVANCE DE 27.0
ST FTRM1 % -5.1
LT FTRM1 % 4.6
ST FTRM2 % -1.0
LT FTRM2 % 3.9
VEH SPEED MPH 45
FUEL SYS 1 CLSD
FUEL SYS 2 CLSD
O2S11 V 0.360
ST FTRM11 % -1.0
O2S12 V 1.000
O2S21 V 1.080
ST FTRM21 % -2.2
O2S22 V 1.000
PTO STATUS DISEN
OBD2 STAT CA
Frame 10 Time 61.0
MIL STATUS ON
ABSLT TPS % 17.2
ENG SPEED RPM 1653
CALC LOAD % 12.1
MAP KPA 44
COOLANT F 188
IAT F 113
IGN ADVANCE DE 16.0
ST FTRM1 % -5.1
LT FTRM1 % 0.7
ST FTRM2 % -7.7
LT FTRM2 % 0.7
VEH SPEED MPH 43
FUEL SYS 1 CLSD
FUEL SYS 2 CLSD
O2S11 V 0.880
ST FTRM11 % -3.4
O2S12 V 1.000
O2S21 V 0.300
ST FTRM21 % 0.8
O2S22 V 1.000
PTO STATUS DISEN
OBD2 STAT CA
Frame 11 Time 67.0
MIL STATUS ON
ABSLT TPS % 12.9
ENG SPEED RPM 1090
CALC LOAD % 7.0
MAP KPA 36
COOLANT F 190
IAT F 116
IGN ADVANCE DE 16.0
ST FTRM1 % -6.3
LT FTRM1 % 0.7
ST FTRM2 % -4.6
LT FTRM2 % 0.7
VEH SPEED MPH 19
FUEL SYS 1 CLSD
FUEL SYS 2 CLSD
O2S11 V 0.340
ST FTRM11 % -3.4
O2S12 V 1.000
O2S21 V 0.300
ST FTRM21 % 0.0
O2S22 V 1.000
PTO STATUS DISEN
OBD2 STAT CA
Frame 12 Time 73.1
MIL STATUS ON
ABSLT TPS % 12.9
ENG SPEED RPM 759
CALC LOAD % 4.3
MAP KPA 37
COOLANT F 192
IAT F 120
IGN ADVANCE DE 26.0
ST FTRM1 % 3.1
LT FTRM1 % 3.9
ST FTRM2 % 3.9
LT FTRM2 % 2.3
VEH SPEED MPH 3
FUEL SYS 1 CLSD
FUEL SYS 2 CLSD
O2S11 V 0.400
ST FTRM11 % -2.2
O2S12 V 1.000
O2S21 V 1.000
ST FTRM21 % 0.0
O2S22 V 1.000
PTO STATUS DISEN
OBD2 STAT CA
Frame 13 Time 79.2
Old Apr 24, 2009 | 09:51 AM
  #53
mopowar's Avatar
mopowar
Refresh my memory, what o2 sensors are you using where are they installed? Something is screwy with those readings. o2 sensor voltages should bounce back and forth between ~.2v and ~.7v. For ex., the last frame looks normal except for both sensors on bank 2, and the downstream on bank 1 all read a full volt. Downstream- I'm guessing maybe you gutted the cats or don't have the sensors installed? If it is a fueling issue, it is on bank one. You can get away with -24, but -33 is pegged. The m1 flash from B&G will come back with -20 to -25 fuel trims. I would check every thing I mentioned before.
Just so you know. With the exception of the downstream sensor voltages, frame 11 is abouthow everything should look.
Old Apr 25, 2009 | 08:07 AM
  #54
ICEMAN_CH's Avatar
ICEMAN_CH
I am using universal O2's at the moment. I'm looking at some Denso's they end up being about 57$ each I just need to figure out wich ones to get. There are like 40 differnt O2 sensors for an 01. The O2 sensors are located on the collectors of the headers and you are correct the rear O2 sensors are not even installed.
I went to my mechanic freind and talked about it. He thought that maybe it was the O-rings on the fuel injectors. So he started digging around and sprayed some brak cleaner on the intake. He said there was a change in the RPM but, I couldn't tell. He says this would mean that the intake gasket had a hole in it. This dosn't make sense to me. I mean it kinda fits the problem but on the other hand why would the turning the truck of and then on imedietly fix the problem everytime.
What would cause a fueling issue?
Old Apr 27, 2009 | 02:17 PM
  #55
mopowar's Avatar
mopowar
NTK's are the best for the money. A manifold/vacuum leak would help with a rich condition. O-rings would leak fuel out, not in.
Any of the things I mentioned before could cause over-fueling, i.e. too much pressure, injector(s) sticking open. Looking back over the freeze frame #'s, I don't understand why why one bank is in closed loop, and one in open loop at the same time. Then Again, like I said before, I have never really messed with cali emissions. Try posting that data up here:
http://www.bionicdodge.com/bionic/
with an explanation of the problem. Maybe Marty or Hemifever will chime in. They know these boxes inside and out, and will atleast be able to tell you if the fuel driver is acting right.
Old Apr 27, 2009 | 11:09 PM
  #56
ICEMAN_CH's Avatar
ICEMAN_CH
As far as the system being open on one side it may be that I need to tighten the botls on the headers yet again. I don't think they have quite finished their break in yet. Also it is the first time that I have noticed one opening and not the other. I'll go post on that site right now I think I still have an account there.
Old May 15, 2009 | 11:52 AM
  #57
ICEMAN_CH's Avatar
ICEMAN_CH
Ok I I finally found some O2 sensors that will fit my truck. I had to order them for a 2002 but, they fit perfectly. The plus side was that they are longer then the 01 to so they fit without splicing. All I can say is wow what a differnce. The headers made a big differnce but, having the right O2 sensors made a big differnce to. I haven't had the problem yet but, I've only started it once so I'll have to wait and see.
