96 Ram 2500 brake noise
Old Apr 4, 2009 | 12:40 PM
Gotta feed them horses's Avatar
Default 96 Ram 2500 brake noise
My 96 ram 2500 v1o is making a loud screeching noise on one of the breaks and I don't know if it is front or back or even what side. It is really loud and is getting worse. It generally only squeaks at moderate brake pressure and will stop if I press the break harder. If I hold the break right at the pressure where the squeak is it squeaks like something is bent and scrubbing. Any ideas????
Old Apr 4, 2009 | 01:34 PM
J415's Avatar
J415
what your hearing is either the front "screamers" or the rear rivets on the brake pads. take you front tires and look for a flat metal hook at the front of the pad. if it's touching the rotor then your brakes are gone. get new ones and have the rotors turned. If its not the front then it's the back. It might be hard to take the rear drum off if you've been dealing with that noise for a while. the pads might have dug into the drum. Either way, take the drum off and check the pads. if the metal rivets are leveled off with the pad material, you need new pads. Have the drums turned also if they are the pads that are gone. MAKE SURE TO CHECK BOTH FRONT AND REAR. YOU MIGHT HAVE BOTH FRONT AND BACK SCREECHING. Hope that helped some.
Old Apr 4, 2009 | 02:30 PM
TMS Bill's Avatar
TMS Bill
If the wear sensor on the pads is screeching ... take a hard look at the thickness of the friction material. I had one screaming at me but when I checked the pads, they had more than a 1/4" of material left ... WAY to early to replace them. If that's the case, bend the sensor back to a more realistic depth and press on.
If there's no sensor ... the pad thickness will be a dead giveaway ... as will the severe scoring of your rotors.
If it's the rear ... the SHOES will have already scored up the drums as there's no wear sensor back there.
Old Apr 4, 2009 | 03:29 PM
J415's Avatar
J415
I feel like an idiot. I said rear pads not shoes when there drums. I thought there were wear sensors in the back. not like the disk pads, but in the form of rivets. once your rivets are level with you SHOES, then its time for new SHOES,right? Check it out TMSBill, I said SHOES twice (three times including this one) in order to make up for my f#*k up.
Old Apr 4, 2009 | 04:23 PM
TMS Bill's Avatar
TMS Bill
Just yankin' your chain.
I've seen a LOT of people refer to shoes as pads ... and not as an honest mistake either. They really don't know what a shoe is.
By the time you hear the rivets scoring up your drums, it's too late. I've only found rivets on OEM shoes ... the aftermarket variety are usually bonded so there's less chance of tearing up your drums if you leave them on too long. It's also cheaper for them to make.
Old Apr 4, 2009 | 04:33 PM
I went on a mission to figure out what wheel was screaching. It is definately th front right. I guess my pads wear unevenly because the truck does tend to pull to one side when stopping hard. I'm gonna take the wheel off and have a look after lunch if I can find a tire wrench...
Old Apr 4, 2009 | 04:35 PM
zman17's Avatar
zman17
Retired Moderator - RIP
I bet the slides are rusted solid and the inner pads are shot.
Old Apr 4, 2009 | 06:12 PM
Well the front right is fine and now I realize that it is actually the back right. I' going to take it off next and try to figure out this whole drum deal
Old Apr 4, 2009 | 07:05 PM
TMS Bill's Avatar
TMS Bill
You know how to back the adjusters off, yes?
