01 1500 4x4 on way to tranny shop
Started kicking out of overdrive , then trans temp light comes on now has trouble shifting between gears. Have not drove in 6 months. All this at 60,000. Guy seems to know how to fix it. Any up grades I should bring up. I have bugged him to death with questions. just want the most for my $. Best convertor to use. Should I pull out anti drain valve. I pull trailer 4 dune buggy and 4 wheelers. 33/1250 tires do these affect overdrive.
Should go in next week if I can convince myself this is the place to do the job. still afraid $1500 estimate will turn into $2500. Have heard others this has happened too. Has anybody ever got a straight answer from a tranny guy. He says dodge convertor falls apart and can plug lines. I had truck scanned at a shop and got solenoid code and overheating at over 385 degrees. when I put my temp gun on pan and on fluid on dipstick it was within operating range. All they say is we can take it apart.
Trending Topics
How does the truck drive when shifting manually? If it shifts fine manually shifting, it's probably an electrical issue and not a full rebuild, which I'm assuming is what they are quoting you?
Check the codes, use the key method, post what the odometer tells you. My truck has 62k on it and went through some electrical issues this winter.
