Upper Dash Removal
Old Apr 9, 2009 | 01:39 PM
ckoons22's Avatar
ckoons22
Default Upper Dash Removal
This may be a N00b question/ repost, and if so I'm sorry but if someone could help I would appreciate it.
I was wondering if anyone has removed the top dash before I have all the screws on the drivers side removed but the passenger side is still tight. Yes I have all the screws on top on the dash by the wind shield removed. Its tight by the glove box area. Are they clips or more screws?
Old Apr 9, 2009 | 03:24 PM
PurplDodge's Avatar
PurplDodge
You have to tilt the dash forward to get to all the screws. There are screws around the defroster vents that face towards the front of the truck. Did you remove the airbag?
BTW open up your Haynes manual or download the FSM in the DIY section.
Old Apr 9, 2009 | 04:21 PM
mcss8541's Avatar
mcss8541
you have to remove the braket holding up the steering wheel shaft and let it down and rest on your driver's seat. there are some bolts under the dash on both the driver's side and passenger side against the sides of the vehicle.
