Choosing a muffler
Old Apr 9, 2009 | 02:38 PM
RangerGress's Avatar
RangerGress
Default Choosing a muffler
Recently bought a '99. PO had a sport muffler on it that's too darn loud. So I'm on the prowl for a pair of inexpensive quiet mufflers. Muffler shop wants $350. I'm in a small town so the local pick-n-pull doesn't have any 2nd gen Rams. Questions:
1) I'm thinking that I could just find a couple generic looking mufflers in good shape at the pick-n-pull and they'd work just fine. That reasonable?
2) If the above is a bad idea, what other vehicles used a muffler about the same size.
I'm in Savannah, GA. If anyone wants a pair of loud mufflers, they're about to become available.
Later edit: See post #6. Its not 2 mufflers but a single "2 into 1".
-Scott
Old Apr 9, 2009 | 02:40 PM
Viper37's Avatar
Viper37
I've always been a huge fan of the factory muffler. Just enough noise to know it's a V8, but not noisy enough to bother anyone or sound like crap. See if you can find one in a yard.
Old Apr 9, 2009 | 02:42 PM
Ram2K1's Avatar
Ram2K1
If your muffler shop wants $350 for factory replacements they are nuts. I would say look for mufflers on any full-size truck with comparable engine specs at the junk yard and you should be fine...doesn't have to be from a Dodge. What kind are on it now?
Old Apr 9, 2009 | 02:48 PM
RangerGress
I'm not sure what the brand is. There's no obvious manufacturer's markings. They're little things about 14X12X6 inches.
Thanks for the info. I'll head to the pick-n-pull this afternoon and snoop around.
Old Apr 9, 2009 | 03:29 PM
xskylinedx's Avatar
xskylinedx
I know that dynomax makes replacement mufflers with large cases which should give a
quiet tone. I think you can get into a 32 inch case length. I don't believe they are very
expensive.
Old Apr 9, 2009 | 08:45 PM
RangerGress
I screwed up and got my "vehicles with muffler problems"confused. The Ram has a 2 into 1 fairly OEM looking muffler. I figure that a muffler shop ought to be willing to replace that with something quiet for far less then the $350 they quoted when I told them 2 individual mufflers.
Any ideas on more clever solutions to replace a loud 2 into 1?
Old Apr 10, 2009 | 12:00 AM
xskylinedx's Avatar
xskylinedx
if you have a 2 into one muffler with 2.5'' inlets and a 3'' outlet I can point you to a muffler
a little over $100.
Old Apr 10, 2009 | 12:20 AM
J415's Avatar
J415
check summitracing.com for some dynomax turbo muffler. They have a nice, mellow tone to them.
Old Apr 10, 2009 | 03:00 AM
dakotas ram's Avatar
dakotas ram
put some tailpipes on the one you have without tips and it will quieten it down a lot if it doesnt already have pipes
rockauto.com has stock replacements for under $100
