Anyone Local to Virginia??
Old Apr 20, 2009 | 11:17 AM
sungod's Avatar
sungod
You put 2qts in the rear? Scary! Where did it go? either the gasket on the cover was/is bad or your drums/shoes must be coated with gear oil. I hope you found the leak or else you will be in the same situation soon enough. If you have a limited slip, i hope you added the friction additive.
Old Aug 14, 2009 | 10:48 PM
99_ramsport's Avatar
99_ramsport
Bringing the thread back to life but i'm in Manassas and new to the dodge rams also. If anyone is in the area and has fooled around w/ these trucks before please hit me up. I have a checklist i need to fix on the truck... Mostly little stuff but could use some help. I have tools!!
Old Aug 14, 2009 | 11:43 PM
pavement_hater's Avatar
pavement_hater
2qts is pretty much empty as they only hold around 2 1/2 max. Probably lots of wear on the gears. Be ready to replace it all.
Old Aug 18, 2009 | 04:02 PM
99_ramsport
anyone near Manassas...? i have a few "DIY's" coming up and could use a hand..
Old Aug 18, 2009 | 04:24 PM
wjxavier's Avatar
wjxavier
i live in quantico actually...not that far away.
Old Aug 18, 2009 | 05:01 PM
99_ramsport
pm'd!!
