Transmission Failure- Action Plan
Old Apr 26, 2009 | 10:29 AM
  #21
lv360ram's Avatar
lv360ram
Originally Posted by Marksman
Does anyone know where I can cross-reference the number I pulled off the side of the transmission? It sounds like I have an RE, but the dealer from my vin# said it could be an RH.
Plus lv360ram says there should be 8 pins in a connector where I have 3.
The 3 wire connector you see is prolly the P N switch which horizontal in the side of the case. The 8 wire connector is vertical and higher up the case.
I concur and agree you have a 46RE. (nice rhyme, huh?)
Old Apr 27, 2009 | 09:01 AM
  #22
Marksman's Avatar
Marksman
Thanks everyone. RE it is!. Call the dealer, plus all the help here.
Great reminders about the aux cooler ad check valve. Is there a good procedure to flush those lines radiator and aux cooler?
Pretty sure I'm just going to find a used tranny.
Does anyone know if there is a cross reference for this swap. The RE ran many years.
So I'm looking for a 1996 up until what year?
Thanks again.
Old May 31, 2009 | 10:06 PM
  #23
MonteC's Avatar
MonteC
Converter or pump failure. Hopefully you have gotten it rebuilt or found a used one by now. I just received your pm.
