Rear Posi and Front Locker
Old Apr 14, 2009 | 12:35 AM
Relex's Avatar
Relex
Would I be better off getting LSD in the front?
Old Apr 14, 2009 | 12:46 AM
dodge15004x45.9's Avatar
dodge15004x45.9
Sounds like it.
Old Apr 14, 2009 | 02:07 AM
Relex's Avatar
Relex
:edit:
Sorry double post somehow, internet is acting up tonight.
Old Apr 14, 2009 | 07:31 AM
dhvaughan's Avatar
dhvaughan
depends on your driving habits.
if you drive on paved roads in 4wd, get an LSD.
if you NEVER drive on paved roads in 4wd, (or you got big $) get a locker
if you get a locker and you can afford it, get a selectable locker, and then leave it unlocked on paved roads. otherwise it'll slide through a turn and you'll end up in the ditch. the lockers require friction to unlock and roll through a turn. on ice or packed snow you may not get that friction, and the tires spin/slide instead of turn/roll.
Old Apr 14, 2009 | 09:17 AM
Mr. Jimmy's Avatar
Mr. Jimmy
I've got a Powertrax no-slip in my 4x2 and it has been great. However, you do need to adjust your driving habits and be easy around the corners, or you will get some chirping. Traction is 100% better.
I have heard Detroits are better and they offer more options in types of lockers, but I have no personal experience with them.
Old Apr 14, 2009 | 09:28 AM
xskylinedx's Avatar
xskylinedx
If your not going to get into huge tires and lots of horsepower then a powertrax no-slip
will work great in the rear end. However, if you plan on doing either one or both you
should get a detroit because they are strong as hell. I personally would not get a full time
locker or a lsd unit in the front axle, I would get a selectable locker. That way you can
have the road manners of an open diff in the front with the option to fully lock it under
poor traction conditions.
Old Apr 14, 2009 | 10:17 AM
Relex's Avatar
Relex
I want to build my truck up for the mud. I plan on doing a lift and eventually getting a stroker kit once its paid off. I live in Pa so the winter very but this past year I don't ever remember driving around in 4wd in snow unless I had too.
Old Apr 14, 2009 | 12:31 PM
dsertdog56's Avatar
dsertdog56
You do NOT want to run a front locker in the mud, because you willl not be able to steer your truck. I've even kinda rethought having a LSD in the front for mudding.
If I were you, I'd visit with people locally who run in mud and ask what they run.
A good locker tends to make any 2wd truck as capable as an open diffed 4x4 or one with a rear LSD in many situations
Old Apr 14, 2009 | 01:24 PM
Gotta feed them horses's Avatar
I rode in a truck with a locker and we were going down the freeway and all of a sudden there was a loud *** bang.... it scared the crap out of me... it was the locker....
Old Apr 14, 2009 | 01:32 PM
Ninety5PoloZ's Avatar
Ninety5PoloZ
My buddy he is going to put my new gears in. He said pay someone to do the locker. He built a mitsubishi eclipse that ran 153pmh at 11.30 with 28 lbs of boost.
Time slip??? Thats a horrible 1/4 mile time if he was trapping at 153mph, thats like a mid to low 9 second pass
