No Oil Pressure
Old Apr 14, 2009 | 11:06 PM
dblj16380's Avatar
dblj16380
I've heard that you basically have two different options to remove the oil pan.
1) Jack up the engine a slight bit and unbolt the pan. Then remove the pan
2) Remove the starter and trans inspection cover. Unbolt the pan and remove
Basically from what I have read the Haynes says to lift the engine to get clearance for the oil pan over top of the transmission inspection cover.
Old Feb 4, 2010 | 11:19 PM
jbahlz's Avatar
jbahlz
Default same problem
did you have to replace main seal, i got the pump out but looks fine, so i think i have to do main seal, no idea how thats done
Old Feb 4, 2010 | 11:22 PM
2001Ram's Avatar
2001Ram
Is the high volume pump really worth it? What makes it better?
