turn signals flash like strobes
Old Apr 15, 2009 | 02:53 PM
johnyredd99's Avatar
johnyredd99
Default turn signals flash like strobes
I have a 94 ram 2500 and the turn signals on both sides flash like strobes. All four corners work but but flash extremely fast. Indicator lights inside truck flash as fast as exterior lights. when i turn on the 4 way hazards all four corners flash at normal speed. Any help would be great. thanks
Old Apr 15, 2009 | 03:06 PM
charlie1935's Avatar
charlie1935
Try a heavy duty flasher.
Old Apr 15, 2009 | 03:19 PM
Gary-L's Avatar
Gary-L
Veteran: Navy
Your flasher relay is faulty, hence the quick blinking.
Old Apr 15, 2009 | 03:25 PM
Laramie1997's Avatar
Laramie1997
1+ check the relay. If you think its bad you can swap out one of the other relays in the box to check it.
Old Apr 15, 2009 | 11:00 PM
dblj16380's Avatar
dblj16380
I'm not sure about our trucks, but I know on my grand prix I used to have there were two flasher relays. One for the standard turn signal usage and the other one was specifically for the hazard lights. I would check the flasher relay. Rather than buying a new one right away you could just swap the two that you have and see if the problems switches over to your hazards.
Old Apr 15, 2009 | 11:48 PM
dodge15004x45.9's Avatar
dodge15004x45.9
I would leave it alone I like lights that flash. (look at the light bar)
Old Apr 15, 2009 | 11:56 PM
PurplDodge's Avatar
PurplDodge
Why??????????? That is ****ing stupid!!
Old Apr 16, 2009 | 12:21 AM
dodge15004x45.9
Casue it looks better Being a vol. ff more flashing lights the better! I dont get hit by cars going to help some one.
Old Apr 16, 2009 | 12:28 AM
jagass's Avatar
jagass
There's a prob with the flasher...
Old Apr 16, 2009 | 11:49 AM
J415's Avatar
J415
Some might think that "hemi orange" grill inserts are "****ing stupid!!" but if thats what you like then thats cool. If thats what he wants to do with his flashers then let him. To each his own.
