2wd lift
Old Apr 22, 2009 | 01:53 AM
  #31
dakotas ram's Avatar
dakotas ram
why is that scary?......so the part you had to grind is right below the top strap mount correct? iwas lookin thru your old posts.....did you ever get longer shocks or just those extenders?
Old Apr 22, 2009 | 03:17 PM
  #32
dodgeram07's Avatar
dodgeram07
dakotas ram,
you have to take in to consideration that viper's truck is an 01 and the front suspension( (upper control arm, spindle, etc.) is all different, that all changed in 2000,
so just think about that, also if you are worrried about the bump stop grinding thing off, just jack the front of the truck up to see if it will hit( full suspension maxed out)
Old Apr 22, 2009 | 05:04 PM
  #33
ram1wheelpeel's Avatar
ram1wheelpeel
from the 99 model to the 2000-01 model, didn't dodge just go from a front serviceable bearing to a non serviceable bearing?
viper
did you not add the limit straps to keep the front end from riding to high so you could get it aligned properly? or was it to keep it more level with the rear? or so your control arm/spindle wouldn't hit anything? if i remember you installed 2.5" spacers, right?
Old Apr 23, 2009 | 12:09 AM
  #34
dakotas ram
mines a 95..... from what im understanding the straps are for when youre catchin air or whateve to make sure it doesnt all spring apart.....
Old Apr 24, 2009 | 10:09 PM
  #35
dakotas ram
viper.....did you end up getting longer shocks or just the extenders?......
Old Apr 25, 2009 | 12:39 AM
  #36
dodgeram07's Avatar
dodgeram07
longer shocks,,, i know mine not viper
Old Apr 25, 2009 | 12:46 AM
  #37
Viper37's Avatar
Viper37
Longer shocks.
