14x3 air kit
Old Apr 16, 2009 | 12:26 PM
Steel Horse's Avatar
Steel Horse
Default 14x3 air kit
Ok so i dont want to spend 350.00 bucks on a K&N cooler intake. So i see a lot of people on here that have 14x3 on em. Ive called around and know one seems to know what the hell im talking about. What do i have to do to fit a 14x3 air kit on my truck? Is it a kit? is it custom built? And where can i order it from? How does it fit and is it better than a k&N cooler intake?
Old Apr 16, 2009 | 12:29 PM
Laramie1997's Avatar
Laramie1997
Try the search feature. ITS AMAZING!
Just joking, but seriously, there are thousands of threads on that topic floating around just search a little bit.
Old Apr 16, 2009 | 02:45 PM
94Beater's Avatar
94Beater
Use this one
http://cgi.ebay.com/ebaymotors/14-x-...Q5fAccessories
You also might have to get a crankcase breather filter or connect your air filter with existing breather cap.
Old Apr 16, 2009 | 03:57 PM
Cereal Killer's Avatar
Cereal Killer
Check these two threads out steel horse. They should give you all the information you need.
https://dodgeforum.com/forum/2nd-gen...er-update.html
https://dodgeforum.com/forum/2nd-gen...k-no-more.html
Old Apr 17, 2009 | 01:37 AM
99DRAM31887's Avatar
99DRAM31887
ok i would like to do this mod too to get rid of my cai and what kinda small breather is needed to put in the valve cover on the drivers side ?? j/w
Old Apr 17, 2009 | 09:14 AM
Silver_Dodge's Avatar
Silver_Dodge
Wow. Did you even read the links that were in the posts right above yours?
Old Apr 17, 2009 | 12:52 PM
dsertdog56's Avatar
dsertdog56
Whyyyyyyyyyyyyyyyy would they do that? Seriously its covered in the links. With a bit of fab work you can run the stock breather tube into the AC assembly as well.
Sorry to say but if you can't figure out how to get a 14x3 chrome air cleaner (after reading the links) from any parts store put on your truck, you do not want to try an install a K&N system.
EDIT: I know that previous statement might sound harsh, it wasn't meant to be so. There is a bunch of personal experience behind it.
