Ram 1500 catalytic converter
Old Apr 16, 2009 | 05:43 PM
nathangfnd's Avatar
nathangfnd
Default Ram 1500 catalytic converter
MMMMM K
I was wondering what the exhuast pipe size is that goes from the headers to the catalytic converter.
Im talking about the dual pipes that enter in front of the Cat and yes it is all stock from the manufacture.
Old Apr 16, 2009 | 06:30 PM
Ram2K1's Avatar
Ram2K1
Probably either 2 or 2.25" if it's stock...the piece you are talking about is the y-pipe, right?
Old Apr 16, 2009 | 07:34 PM
nathangfnd's Avatar
nathangfnd
yes it is called the Y pipe but i dont see why. It is a Y yes but it is part of the Cat.
I am going to get a Magnaflow 10 in Y pipe with dual 2 inch inlets and a single 2.5 inch outlet.
Im going to cut the 2 pipes going from the motor to the Cat off as close to the Cat as possible and throw the Y pipe on and piece together.
That way i can keep the stock o2 sensor placement and the two foot single 2.5 inch pipe will hopefully keep the backpressure at a good level. and i will try the 2 spark plug non fouler trick. if it dont work i have run for 4 hours without the o2 sensor plugged in without a CEL so hopefully itll work if not i dont care if there is a CEL
my old truck had true dual strait pipes from headers back and it had 2 flow through mufflers. It was great. i saw it driving right in front of me a week ago and loved the sound it had so i decided to try do my own without messing with o2 sensors.
Old Apr 16, 2009 | 07:36 PM
CRNA's Avatar
CRNA
2"....just replaced my entire cat and exhaust
Old Apr 16, 2009 | 07:53 PM
nathangfnd's Avatar
nathangfnd
it cant be 2.5 inch. The single rear exit is 2.5 but the front y pipe is 2 inch. i just found a site that sells stock replacement parts and it said dual 2 inch inlet and singlw 2.5 inch outlet.
And i found my tape measure and it shows 2 inch outside diameter
Old Apr 18, 2009 | 12:52 PM
Ramcharger1's Avatar
Ramcharger1
A completly new Y-pipe is avalible from Summit Racing, complete with the pre- cats an the catalytic converter all ready put together. It is made by Magnaflow an the PN is MPE-43206. It is Cal Carb compliant.
Old Apr 18, 2009 | 01:00 PM
nathangfnd's Avatar
nathangfnd
i dont want a new CAT i want to take it out. We in North Dakota have no emission checks or anything.
Old Apr 19, 2009 | 08:37 PM
Ramcharger1
Well if you want to just remove it, Summit Racing also sells a Y-pipe without the cats on it. PNPSM-82-1183. It is a 3" dia pipe. Bolts up to either the stock manifolds for shorty headers.
Old Apr 19, 2009 | 08:42 PM
dakotas ram's Avatar
dakotas ram
yep 2" on mine
Old Apr 19, 2009 | 08:58 PM
nathangfnd's Avatar
nathangfnd
ust looking at the y pipe from summit and from the pic it doesnt show the connector to the headers. The 2 bolts that go from header to the exhaust are not there. so basically i would have to or 2 of them and get them welded on and the ball flange kit is like $100 without welding.
http://store.summitracing.com/partde...700+4294840106
