deep tranny pan.
Old Apr 17, 2009 | 11:39 PM
dsertdog56's Avatar
dsertdog56
Are you fellas insinuating that size matters?
+1 on buying the correct depth pan...and I believe that cooler design and size has more to do with reducing heat than pan capacity.
Old Apr 18, 2009 | 12:36 AM
Silver_Dodge's Avatar
Silver_Dodge
Originally Posted by Cereal Killer
I wonder if the fact that your tranny cooler is almost the size of your radiator has any effect on that?
No, my trans cooler dropped my temps by about 25-30 degrees. The pan was installed later, and dropped the temps that little bit more.
Old Apr 18, 2009 | 12:39 AM
dodge15004x45.9's Avatar
dodge15004x45.9
What did that pan cost you all said and done? Did it come with a new gasket?
Old Apr 18, 2009 | 03:45 PM
aim4squirrels's Avatar
aim4squirrels
My pan ran $275 and took 11 quarts to refill. Keep in mind that I removed the check valve from the system so I'm pretty sure both the aux cooler and radiator heat exchange probably drained out over night as I pulled the VB to do some work on it. I think the check valve probably kept the aux cooler from woRking as effciently as it currently does, and a pusher and puller e fan probably helps too.
Old Apr 19, 2009 | 10:51 PM
Acapalic's Avatar
Acapalic
I just bought a PML Deep trans pan, +2 quarts, and machined for sensor, and has a magnetic drain plug. I only payed 233. free shipping. www.moesperfromance.com
I also at this time bought a gauge pillar , and two digital temp gauges with blue leds , one for water , and one for temp.
Old Apr 19, 2009 | 10:55 PM
Silver_Dodge
My PML pan ran me $205 shipped. I bought it through a vendor on another forum, and he gave me a discount over the prive you see on the PML website.
