Abs??
Old Apr 18, 2009 | 01:37 AM
quadracer18's Avatar
quadracer18
Default Abs??
Im looking to replace my front hubs on my truck. Its a 1998 ram 1500 5.2L. I replaced my brakes the other day and I didnt see any wires going to my hubs so now im not sure if my truck is equipped with ABS so i dont know which hubs to buy. Is there a way to easily find out if my truck has ABS? when i start it, i do notice that an ABS light comes on for a second but not seeing the wires come out of the hubs gives me the impression that i dont have it. Any help is appreciated!
Old Apr 18, 2009 | 04:50 AM
jasonw's Avatar
jasonw
Site Moderator
Go to or call a local Chrysler dealer, and give them your VIN number. They can usually print out a spec sheet with everything your truck came with stock.
There is also (forget the exact link) a way to email Chrysler corporate to get the VIN "decoded", but they sometimes take anywhere from a few days to a week or so to get back to you.
These trucks came standard with rear wheel ABS and four wheel ABS was an option (pretty rare).
Old Apr 18, 2009 | 04:59 AM
J415's Avatar
J415
One way is to check the inner side of the rotor for an abs sensor. Also, you can check and see if you have a relay for your front abs. you should do a search for your question, since this is a common question. someone just posted the same topic a couple of days ago.
Old Apr 18, 2009 | 07:48 AM
dhvaughan's Avatar
dhvaughan
if you don't have a visible wire plugged into a hole in the knuckle, then you have rear wheel only abs, and you will need non-abs hubs.
most all of our trucks are rear-abs only. remove the tire and count the hoses/wires on the front. you should see (one) brake hose to the caliper. if there's second wire to the back side of the steering knuckle - that's abs.
