fog lights...
Old Apr 19, 2009 | 09:59 PM
XCRacer90's Avatar
XCRacer90
Default fog lights...
how do i turn them on? is there a separate switch then on the left where the running and headlights turn on?
Old Apr 19, 2009 | 10:03 PM
Viper37's Avatar
Viper37
Pull the switch. Or push. Depending on your year. 98 should be pull though.
Old Apr 19, 2009 | 10:14 PM
XCRacer90's Avatar
XCRacer90
yeah thats what i did. i pulled to first notch and running lights came on. then pulled to 2nd notch, headlights came on.
Old Apr 19, 2009 | 10:17 PM
Viper37's Avatar
Viper37
You have a switch by your radio that controls your fog lights.
Unless they are aftermarket.
Old Apr 19, 2009 | 10:30 PM
dodge15004x45.9's Avatar
dodge15004x45.9
Or you need new light bulbs and or fuse.
Old Apr 19, 2009 | 10:38 PM
Viper37's Avatar
Viper37
Once he's found the switch. He has a pull type switch headlight switch, not a combination turn/pull.
Old Apr 19, 2009 | 10:39 PM
jasonw's Avatar
jasonw
Site Moderator
Viper is right, unless they are aftermarket, if you have a pull **** type switch for the parking lights/headlights, there should be a push button somewhere in the center (around the radio) that you push to activate your fogs.
After you find the switch they should work, unless like Dodge15004x45.9 said, there is a fuse blown or bulbs burnt out. I believe the fuse for the fogs is in the PDC (Power Distribution Center) under the hood on the driver's side.
I doubt both bulbs would be burned out at the same time, but you never know. That's pretty easy to check.
Old Apr 20, 2009 | 07:16 AM
XCRacer90's Avatar
XCRacer90
you guys said exactly what i figured. i was hoping there was another button somewhere that turned them on separately. ill look for that button on my way to school. thanks!
Old Apr 20, 2009 | 10:12 PM
SarcasticDwarf's Avatar
SarcasticDwarf
For the hell of it I am going to try to clarify this:
There are two switches involved in foglight operation: The foglight toggle and the headlamp ****.
When your foglights will be on:
When the foglight switch is depressed (see attachment) AND the headlamp switch is pulled out (I am not sure if they turn on with just the running lights on or if the headlights need to be on as well).
When your foglights will not be on:
When the foglight switch is depressed but the headlight/running light **** is not pulled out.
Old Apr 21, 2009 | 01:40 AM
Maxx_Magnum's Avatar
Maxx_Magnum
the fogs will come on with just the parklights
