1998 dodge ram wrong rotors
Old Apr 20, 2009 | 08:07 PM
carmen77's Avatar
carmen77
Arrow 1998 dodge ram wrong rotors
Hi everyone. New to this forum. I have read a lot thru this forum and I really need help with changing out my front rotors. I have a 1998 ram 1500 2wd 5.2 liter with a rotors that don't seem to match up with anything that the book calls for. The existing rotors have no abs ring, and are attached with a spindle nut and tapered bushings. Any research on the truck results in either a studded rotor with an ABS ring or a floating rotor with no studs. Any ideas would be appreciated.
Old Apr 20, 2009 | 08:17 PM
dhvaughan's Avatar
dhvaughan
so you have a traditional 2wd rotor with an integrated hub with wheel studs. inside the hub you have separate inner and outer tapered roller bearings. the rotor/hub slides over the spindle and a nut tightens up against the outer bearing.
just like my old chevy.
i'll look at rockauto.... here you go.
http://www.rockauto.com/catalog/moreinfo.php?pk=391250
http://www.rockauto.com/catalog/x,ca...,parttype,1896
Old Apr 20, 2009 | 08:46 PM
carmen77's Avatar
carmen77
Default No ABS ring
Thanks but I guess short of measuring it out, there is no way of figuring where these rotors come from. The rotors from rockauto I believe all have the abs ring on the back side. Unfortunately this will not work with my truck.
