ABS/BRAKE Light???? WTF!!!!!
Old Apr 21, 2009 | 07:25 PM
oldschool1969's Avatar
oldschool1969
Default ABS/BRAKE Light???? WTF!!!!!
All right I have a 1998 Dodge Ram 1500 4x4 RWABS and the ABS and Brake lights are on .
The speedometer works perfect at all speeds.
Ive replaced the sensor on the trans
Ive replaced the sensor on the rear dif
Ive replaced the ABS module.
New pads and shoes.
Bleed out the lines.
After all this about after 10 mins of driving or parked with the motor running the lights will come back on.
My brakes work and feel fine, but no ABS
Also my cruise control is not working because of this.
PLEASE HELP!!!!!
Thanks
Old Apr 21, 2009 | 07:34 PM
J415's Avatar
J415
If your cruise control doesn't work, then it's your brake light switch. It's about 20 bucks. change it and reset you PCM and you'll be fine.
Old Apr 21, 2009 | 11:35 PM
oldschool1969
Default ???
Even if my brake lights work fine?
Thanks
Old Apr 26, 2009 | 10:21 PM
cyborg67's Avatar
cyborg67
i would like to know about this also like oldschool1969 i am having the same problem and my brake light sall work fine as well
Old Apr 27, 2009 | 10:06 AM
oldschool1969
Default Sux
Ya, This sux
I did replace my brake switch but I'm still waiting for my ABS module.
My new one was from a donor truck so I sent it in to get it rebuilt by a company that specializes in that stuff.
I'll let you know if that works.
