Por-15
Old Apr 23, 2009 | 11:59 PM
95RamIT's Avatar
95RamIT
Default Por-15
hey guys, im thinking of sand blasting and doing some rust prevent. on my frame. Def will be a work in progress, work from back to front. Hopefully i will be able to do a write-up. Im about to order some POR-15 online, but how much do you guys think i will need? Probably will do my rear axle while ive got the bed and components off. Maybe order a gallon and 2 qts?
Old Apr 24, 2009 | 01:24 AM
RM_Indy's Avatar
RM_Indy
2 qt POR15 & 1qt Metal Ready is enough to do the frame, axles & diff
Old Apr 24, 2009 | 10:06 AM
95RamIT's Avatar
95RamIT
thanks! ill post pics up as soon as i start it, i get home after the weekend of the 16th! im pretty excited about the job
Old Apr 24, 2009 | 11:53 AM
RM_Indy's Avatar
RM_Indy
If your spraying the POR15, you will need more. I thinned it a bit and used a roller, as well as a brush for the tight areas.
FYI, if you get any on yourself and it dries, it will be with you till it wears off
Old Apr 24, 2009 | 01:24 PM
Optimus's Avatar
Optimus
POR-15 is more or less intended to be applied right on top of existing rust. It doesn't really like to stick to bare metal. If you're going to be sandblasting things, you won't have any rust left for it to stick to. My recommendation would be to contact POR-15 directly and ask them what you should do.
Old Apr 24, 2009 | 02:54 PM
RM_Indy's Avatar
RM_Indy
It will stick to bare metal as long as you wash it with Metal Ready. Its a zinc phosphate etch
Old Apr 24, 2009 | 03:52 PM
95RamIT's Avatar
95RamIT
hey question Indy, does it matter what thinner to use or just anykind?
Old Apr 24, 2009 | 04:22 PM
dakotas ram's Avatar
dakotas ram
about all you need to know
http://www.por15.com/Data%20Sheets/P...cationInfo.pdf
Old Apr 24, 2009 | 04:46 PM
95RamIT's Avatar
95RamIT
Originally Posted by dakotas ram
yea i tried loading that yesterday but something was acting up on my adobe BUT it worked today so were all set! im going to order it today and hopefully when i get home i can get the ball rolling thanks guys!
