Never changed shocks, how much hassle?
Old Apr 26, 2009 | 06:22 PM
hutch1973's Avatar
hutch1973
Default Never changed shocks, how much hassle?
Title says it all. While I've change motors/bodys/transmissions...etc, never done shocks/struts. For whatever reason, heard it was a pain, and never really owned a vehicle that's needed them before now.
Just ordered Bilsteins for my Ram, but going back and forth on if I want to change them. With shipping, shocks are going to run $213. Found a guy online who has a small shop, says he would do it for $80. Thinking shocks installed under $300 isn't a bad deal...and for $80 I might as well not mess with it.
Thoughts?
Old Apr 26, 2009 | 06:23 PM
dodge15004x45.9's Avatar
dodge15004x45.9
The backs are easy the front it a bit more involved.
Old Apr 26, 2009 | 06:25 PM
hutch1973's Avatar
hutch1973
How much time did you have into doing yours?
Old Apr 26, 2009 | 06:34 PM
dodge15004x45.9
Never did them lol Still have to stockers in there I only have 47,800 on my truck I'm going to run them until 60,000 than I'm going up 3". There is 2 bolts for the rear one on top and one on the bottom. Unbolt them take the old ones out. If there gas DON'T CUT THE STRAPS!!!! The front you have to unbolt them form the shock tower and what ever they are bolted to down below. I think thats it for the front.
Old Apr 26, 2009 | 06:50 PM
hutch1973's Avatar
hutch1973
ooohhh...lol...thought you'd done it.
Wow that's low mileage...mine has 62k but they are shot.
Old Apr 26, 2009 | 06:54 PM
dodge15004x45.9
yea sorry the rears are easy and the front needs to be unbolted form the tower. You just need some wd-40 and hands tools or air gun.
This should help as well.
http://wiki.answers.com/Q/How_do_you...1999_dodge_ram
Old Apr 26, 2009 | 07:00 PM
Gary-L's Avatar
Gary-L
Veteran: Navy
WD-40 is for amateurs Geez, have you ever worked on anything? You seem to postwhore like a fiend when someone asks a question, but you never have any experience to back it.
To the OP: Shocks are easy. You'll need an impact gun or a ratchet and a socket. When I did the rears on my truck, I bought the heavy duty towing shocks, which necessitated the use of a prybar to get the shocks wedged into place. Before reinstalling the bolts/nuts, coat all threads with anti-seize to make future removal easier.
For the fronts, it's easier to remove the wheel of the side being replaced. Always place the vehicle on a level surface and on a jackstand. You may need to use heat (propane torch) and alternate with some PBlaster (much better than WD-40) on the threads of the lower passenger side mount. I had to cut the shock because it had frozen to the mounting stud. To prevent issues in the future, I coated the shock mount and the threads with anti-seize. If you have a couple of extra hours, do it yourself and save $80 to put into the fuel tank.
Old Apr 26, 2009 | 07:03 PM
hutch1973's Avatar
hutch1973
Might tackle it if it's only a few hours, that's my main concern, the money isn't that big of a deal. Just filled the tank today, probably will last a month and a half with as little as I drive.
Old Apr 26, 2009 | 07:08 PM
dodge15004x45.9
Geezs sorry!!! I didn't mean to step on yr toes here! Sorry my trucks is not a rusty pice of $hit like yr is and the fire house has WD-40 so I use that cause its free. I have helped my dad when he did the rears on his truck and the rears on our van so yes I do have a small clue of what I'm doing for the rears. At least I told him the tools that he will need. I also gave him a link as well to make up for my lack of knowledge.
Old Apr 26, 2009 | 07:11 PM
dodge15004x45.9
Mine last about 1.5-2 weeks. Yea I know my truck has low milage on it got is 1yr ago with 37,300+ on it.
