Long tubes
Old Apr 29, 2009 | 12:20 AM
OlRed's Avatar
OlRed
Default Long tubes
Pacesetter offers quik-trip long tubes for my our rams. I have an '01 5.2l 4x4 and these are the only long tubes i have found that fit the 4x4. Does anyone have any experience with these? (not shorties) how hard is installation?
Another thing, they come into a 3 inch collector. With a 5.2, is 3 inch true duals a little to much? I remember reading that 3 inch single or 2.5 inch dual is best for these engines. I was thinking of running these headers reduced into 2.5 inch true duals. They come with o2 fittings so i would run 2 o2 sensors up front and get a tune to delete the rear one. Would this set up work. What is everyone running with long tubes, if anyone has any? either 5.9 or 5.2 advice welcome.
Thanks,
OlRed
Old Apr 29, 2009 | 02:24 AM
dakotas ram's Avatar
dakotas ram
3 in duals would be a little much.......3 in single is about perfect.......if you are gonna run duals, put in an x or an h to help with your lowend, then put your front o2 sensor in there and geta sim for your back
Old Apr 29, 2009 | 03:48 AM
helms's Avatar
helms
3" single or 2.5" dual is good for a mid-high rpm 5.9. a low rpm 5.2 would be better off with a 2.25" dual or maybe even 2" although that sounds pretty small.
Old Apr 29, 2009 | 04:01 AM
dakotas ram
i got a single 3" on my 5.2 with no complaints
Old Apr 29, 2009 | 09:07 AM
acsamples79's Avatar
acsamples79
^ Same here
Old Apr 30, 2009 | 02:12 PM
lb79theone's Avatar
lb79theone
From: Maine! ( GET A HOLD OF ME IF YOU WANT TO GET ME ON FACEBOOK.COM, AND CARDOMAIN.COM)
I got 2.5. Its perfect! I got the LTZ longtubes from pacesetter, there mint!
Old Apr 30, 2009 | 02:40 PM
dodge15004x45.9's Avatar
dodge15004x45.9
Long tubes you will need a new y pipe. Unless your going to do a custom.
Old Apr 30, 2009 | 03:39 PM
pcfixerpro's Avatar
pcfixerpro
Im pretty sure you have 3" as I recall. 3" y pipe to 3" cat. I could be wrong but thats what I seem to remember.
Old Apr 30, 2009 | 04:56 PM
Cereal Killer's Avatar
Cereal Killer
Headers to a "Y" pipe, then fake duals? That wouldn't make any sense...
Old Apr 30, 2009 | 06:10 PM
pcfixerpro's Avatar
pcfixerpro
If your talking to me, for some reason I thought neon had bought the LT's and the 3" pacesetter y pipe and then had the 3" magnaflow cat. Then yes prob fake duals. He prob used the single in dual out super 44 muffler like I had. I could be wrong but I thought that was his setup.
