Timing
Old May 2, 2009 | 08:37 PM
Wickedwiggles's Avatar
Wickedwiggles
Alright got er to turn on and idle but when I started to put her into reverse the engine inc. its rpm then it went to a real low idle and cut. Now it wont turn on again seems like the timing went out?
PLEASE HELP!
Old May 3, 2009 | 02:23 AM
dakotas ram's Avatar
dakotas ram
dont know......anyone?
Old May 3, 2009 | 05:29 AM
zman17's Avatar
zman17
Retired Moderator - RIP
Have you checked the fuel pressure?
Old May 3, 2009 | 07:50 AM
dhvaughan's Avatar
dhvaughan
this is beyond my know how and this is just my best guess. assuming that timing chain is right, distributor position is right, wiring is right...
if the distributor has been moved around, you may to set the "fuel sync" with a scanner tool. somebody else explain that more.....
Old May 3, 2009 | 08:06 AM
charlie1935's Avatar
charlie1935
Have you converted to a carburator or still using the fuel injection? On stock type fuel injection the distributor controls the injector pulse, not the ignition timing.
