extrended rear brake line
Old May 1, 2009 | 01:09 PM
postie1686's Avatar
postie1686
Default extrended rear brake line
hey guys im wondering if anyone knows who has a brake line for the rear that goes from the frame down to the axle. i put a lift on my truck and i dont like how tight this line is. thanks
Old May 1, 2009 | 03:00 PM
dsertdog56's Avatar
dsertdog56
EGR brakes, or Earls. Both companies make extended hi quality stainless lines for Rams.
Old May 1, 2009 | 05:33 PM
zman17's Avatar
zman17
Retired Moderator - RIP
You may also be able to remove it and take it to your local part store and see if one from a sport or a 2500 is longer and has the same size connections.
Old May 3, 2009 | 05:03 PM
KY2500's Avatar
KY2500
I think your talking about the hose. Check here http://extranet.soleniuminc.com/centricparts/
Ya a 2500 will be a longer hose. Not sure whether or not you have a 2 wheel abs or 4. You might have a height sensing proportioning valve at the left rear frame connection if 2wheel abs. You might as well delete that if you have it. The new hose comes with the correct fittings to delete. You may need a few c-clips(ace hardware) if the u-clip is rusted at the frame junction.
