Odd Wear
Old May 2, 2009 | 03:41 AM
wlanum's Avatar
wlanum
Default Odd Wear
On my 01 I have some 33" BFG All Terrains and I was noticing some wear on the top portion of the sidewall. What could this possibly be from?
Old May 2, 2009 | 03:47 AM
bgibb68's Avatar
bgibb68
both inside and outside? ----> could be low tire pressure
one or the other -----> toe could be off
Old May 2, 2009 | 07:40 AM
dhvaughan's Avatar
dhvaughan
sounds like low pressure. how much psi you running ?
Old May 2, 2009 | 07:46 AM
aim4squirrels's Avatar
aim4squirrels
Is it on the inner tire surface?
33's in a stock truck might be rubbing on the inside.
Old May 2, 2009 | 01:39 PM
wlanum's Avatar
wlanum
The truck has a 2" level kit in front and if I go over speed bumps while turning or at full lock I think the outer portion of the tire rubs. I was running 26 psi in them because my tire guy calculated that and said it was the lowest I can go. So now the tires are back up to 42 psi but should they be raised? I haven't checked the back side of the tires but I am hoping it isn't bc of a bad alignment since I have had the truck aligned and everything was good.
The wear seems to just be on the top edge of the sidewall not on the outer edge of the rop of the tire
Old May 2, 2009 | 03:09 PM
Ram2K1's Avatar
Ram2K1
Does it get curbed often? Sounds like a rub somewhere to me, too...
Old May 2, 2009 | 04:28 PM
wlanum's Avatar
wlanum
That's what I was thinking too
Old May 2, 2009 | 05:04 PM
helms's Avatar
helms
so you were driving around with 26psi in them? i think you found your problem.
Old May 2, 2009 | 07:46 PM
wlanum's Avatar
wlanum
I was just checking to make sure that wear was because of that reason
Old May 2, 2009 | 08:04 PM
dodge15004x45.9's Avatar
dodge15004x45.9
Haha thats a good PSI for sand!
